- Aug 18, 2014
- 23,833
- 134,230
- Transit PVC
- 16 years since restarting
The UK is about one of the only countries where it can be done. Most others require the kit of whatever it is to come complete with its homologation certificate, Its CoC , which then has to be fitted by an approved garage who then supply another piece of paper stating that it has been fitted correctly & by someone who is autorised .With both pieces of paper the fitment whether, air assist, towbar, bull bars,side bars, rear cycle racks, motor bike carriers, additional driving lights , fog lights,etc;etc; can then be added to the log book.Good info It is an interesting perspective that Joe Public can slap on any DIY suspension system which may adversely affect the handling of a vehicle if not set correctly.
If it isn't on the log book here it isn't legal.
That's the problem for me but has to be done yearly once 10 years oldFor those that have fitted one of these kits how easy would it be to reverse the process and re-install the factory standard rubber bungs ? or are these damaged when you take them out ?
I ask as I couldn't get mine through it's MOT here once I've added such a kit so would need to switch it back before inspection.....
They do but not always for the Uk as not needed. Like when you buy a 'homologated' tow bar.In the UK it does not come with itsCoC homolgation certificate ,whereas here & in other EU countries the identical towbar is supplied with it.This is for my own learning but what approval paper/stamp do you require and to whom must it be presented.
The only reason why I ask is that the VB-Air Maunfacturer supply numerous compliance certifications with its products. I will have to dig them out to clarify the exact contents and fitting caveats etc. I'll try and read them tomorrow.
All the best,
Andrew
No just to fit almost anything requires it to be approved.I.e. you cannot fit most things yourself unless you have a mate that is approved to certify it for you.I think he is referring to get weights on V5 increased axle weights, and to do that you need a plating certificate by a qualified engineer.
