Northernraider
- Jul 30, 2017
- 27,424
- 177,511
- Mobilvetta eurayacht
- On and off since 95
Put the motorhome in for a full mechanical service and full habitation service last Monday ( not sure if I can make the company or not feel free to advise) and to say I'm disappointed and a little annoyed would be an understatement.
I booked it a few weeks ago and although the van has full service history and no known issues because I'm taking it to Spain and Portugal for a year I opted for the full service rather than interim service for peace of mind....total price for both including parts £500
Dropped it off to the garage on Monday morning as requested under the arrangement i get it back Monday night as he was made aware I live in the van full time.
Mechanically I was aware of no issues on the van , I've done 4000 miles in it since September and never had to put a drop of oil or water in it and had zero issues mechanically.
Habitation wise there's been a couple of things I wanted checked out
1) the batteries after an incident a few weeks back where it lost all power in just a few hours.
2) the alde heating system when on gas seems to trip and go off each time usually about an hour after working and you have to disconnect and reconnect a plug on the boiler to reset it and then it will usually run several hours without issue but when you later switch it to hot water only it will cut out again and need reset .
Otherwise there's been zero issues with the van.
So
The vans in the garage Monday and I hadn't heard a word from them by 3pm so I gave them a call just to see where they were at.
Mechanic tells me the van has a diesel leak , and a coolant leak. My tyres are not the correct tyres for the van and should be changed ( I had 6 commercial tyres fitted last month) . Says he hasn't finished habitation service yet but it should be ready to collect at 5pm.
So I get a lift from a work colleague at 5pm to pick up the van
I get there and I'm told they haven't finished , vans still leaking diesel apparently from the filter housing and there's leaks in the coolant system due to 3 corroded hose clips.
He also says he hasn't done the damp test yet but he's had a look at the heating and thinks it a room stat sensor that's the issue so he's fitted one as they are only £13
He says if i leave it with him they can fix the diesel leak and coolant leak the next day and he can finish the hab test.
I decide that's probably the best option and left the van with him and caught the bus back to my mother's and stayed there for the night.
Next day again by around 2pm I've heard nothing from the garage so I give him a call , he tells me that the diesel leak is fixed and the mechanic has the coolant system on a pressure checker to test for leaks before refilling the system but it will be ready to collect at 5pm
I asked him for the total cost and he said he doesn't know yet as the technician hasn't given him the work sheet back yet.
So I head up to get the van , arrive at 5.10
At this point I'm presented with an invoice for £1055.88
To say I nearly fainted is an understatement
The invoice is as follows
Hab service £125
Full mech service £274.17
Truma room sensor £12.40
Fuel filter assy £240.98
3 Hose clips £2.85
7 litres coolant £24.50
4 hours labour £200
Total 879.90
Vat 175.98
Total 1055.88
He announces then that the filter housing was leaking on arrival ( I don't think it was)
And they had to drain the full coolant system to replace the hose clips which were difficult to reach hence between the two it took 4 hours to do.
He states the filter assembly is a genuine fiat part hence the price because the cheaper ones just leak again.
I needed the van back so I paid the bill despite being furious about it.
I asked for the receipt for the filter housing from fiat and was told he didn't have it bit that his invoice was proof enough and that he warranties the part for 12 months
I feel I've been totally ripped off , I don't believe it was leaking when he got it and I also don't believe the coolant was leaking but I can't prove it , I'm also suspicious of whether he fitted an overpriced genuine filter assembly as a quick search on line I can get a genuine one for £76
Although I have checked with local fiat and theirs is £289 ..but without a receipt I don't know if that's what he fitted.
The habitation sensor he fitted resulted in the heating not working at all and I coukd only get it working by removing the one he fitted and putting the old one back on
Although it still trips as before
The damp test he claims he coukd only partially do because the band full of stuff
He marked off carbon monoxide detector and smoke alarm as n/a for some reason despite both being present and in full working order
Noted again that my tyres were illegal for a camper van as they were not camper tyres
I contacted trading standards today and voiced my concerns but they think as I paid the invoice in full and didn't mark it as paid under protest that there's little I can do.
To say I'm annoyed is an understatement
The bill was more than double the estimate and I don't think the work was needed.
Also the peace of mind I wanted I don't have as the guy seems to not have a clue , he hasn't fixed the heating problem, he hadn't checked half the equipment, he doesn't know anything about tyres it would seem and there's not even a detailed description or a tick sheet of what the full mechanical service included
Id like at least to make others aware of this company so they can avoid the same issues....so if I can make them let me know
I've been unfortunately ill again all this week hence me just posting this 4 days later.
Cheesed off
So
Hab service £125
3 Hose clips £2.85
4 hours labour £200
Total 879.90
Vat 175.98
Total 1055.88
Cheesed off
