How much is left?? Gas bottle question... (1 Viewer)
Aug 4, 2021
1,317
7,153
Haslington, UK
Niesmann and Bischof
Hi all, I hope you are enjoying the Bank holiday weekend.
Quick question...I have a 6kg red gas bottle but am unsure how much is left in it..is there any way to work it out or weigh it?
Nov 13, 2011
1,507
3,742
30 years
I believe it is because where there is a volume of gas the heat transfer from the boiling water is different to the empty space above it.
It is very obvious to see when tested like that.
Geoff
G
Aug 4, 2021
1,317
7,153
Haslington, UK
Geoff
I will be trying this out after dinner!
Sep 3, 2012
7,682
26,396
Cheshire
C Class Elddis 175
8+ years
Best just to weigh it and subtract the bottle weight. 1kg equates to approx 2 litres.
  • Informative
Reactions: f6c
Oct 21, 2021
76
278
New Zealand
Mutsubis fuso/canter
5 years
Or get a Mopeka unit.
43,512
51,029
The most accurate way is to pick it up and slosh it around a bit. It's more accurate then any gauge tbh..
Ensuring it's turned off.
I once made that mistake with a 13kg bottle in a superser heater in the house lounge.
Held on its side while I gave It a vigorous shake It spit out a load of liquid gas which set fire to the carpet.
It doesn't burn for long but it's frightening
You can do it by weight but you need to know the empty weight and full weight.
Then you know the weight of gas as a start point.
If there's 10kg of liquid gas when full then 5kg is 50% Etc
Jan 29, 2017
698
565
Gloucestershire
Lunar Champ H621
15yrs
My mopeka kept giving false/poor readings due to the sensor sliding around on the bottom of the cylinder so i replaced the battery in it and overtaped it with gaffer tape. Since then no odd readings.
Good tech that works,, now!
Mike
Sep 4, 2017
264
635
North West, UK
VW T6.1 Transporter
Never stop learning 😊
I have a chart for my little 907 cylinder which claims weight / percentage of gas remaining ratio. Maybe a firtle around Google would give you similar for your bottle?
Aug 6, 2018
57
138
Amesbury, Salisbury, Wiltshire, UK
Rapido A class
Hi there is alist of gas bottle weight in the resources section on here hope this helps. Don’t know how to link to it tho but I had it saved so put it below hopefully link will work for you
Tony
  • GAS BOTTLE DIMENSIONS - V3.pdf
Oct 28, 2022
473
959
Rapido
As Geoff says above, just use hot water. Or if you have scales to hand weigh and substract.
No need for fancy apps or gauges which all seem to be fairly inaccurate.
May 2, 2024
27
29
Monmouthshire, UK
Swift Trekker
Since 2022
I bought one of these simple hand scales from Amazon. Cheap, easy to use, handy for weighing anything really. Tried it with a new Calor Propane 6kg bottle that I bought this week, just to check. The tare weight of the bottle was 8.2kg. On the scale it showed 14.2kg so I have the correct 6kg of propane. It has a tare function too but as I am able to do basic maths I didn't bother with that :)
Dec 24, 2014
9,398
48,516
Hurstpierpoint. Mid Sussex.
Compass Navigator
I weigh mine on bathroom scales and deduct the Tare weight that is stamped on the aluminium collar noting that it's given in Imperial units.
I have had two new 6kg cylinders from the main Calor distributor that were 17% and 15% underweight from the start. I detailed the full story of my follow up with Calor in an earlier thread here........
