Noise , wheel bearing? (1 Viewer)
Jun 17, 2019
478
620
East Yorkshire
Just looking
One a newbie
Hi , just trying to find out if I’m on the right track. My lads Clio makes an (to me) awful noise that increases with speed even with clutch in so assume it is wheel bearings .
This morning I jacked it up spun drivers front wheel and seems fine but passenger side although no major noise feels loose
So I checked wheelnuts and seem tight
But there is definitely play/movement when you pull push on the wheel.
Wheel bearings?
Dec 2, 2019
3,594
7,780
Amersham
van conversion
Since 2019
Check brake pads wear limiter, some pads have a metal tab to let you know they finished. Also disk guard can rub. Bearings usually changes pitch with weight distribution when cornering. I could be bearings if is a high mileage, or driven on bumpy rods most of the time.
43,332
49,498
With wheel off the floor there's no load on the bearing so may well be quiet.
Straight driving may be quiet-ish but corners put a very high load on the bearing and a lot of rumbling.
Cheshirecat57
3,482
5,589
Mid Cheshire
10 years on and off
Does the noise change when turning/ cornering at a constant speed
As you load/ unload the bearing it will change noise
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Find a quiet road or car park drive in Right hand circle that will load passenger wheel bearing and make more noise
than driving in left hand circles weight off the n/s bearing
and visa versa
Apr 22, 2018
6,825
12,585
Herts.
Adria Coral lowline
If there is play in the wheel, that needs to be repaired anyway, and is most likely the cause of the noise.
Does the play disappear if the brake pedal is applied? As the calliper will clamp the disc. The movement of the disc inside the calliper, when wheel is under load, could be the noise.
Jun 12, 2016
1,621
4,356
Scottish Borders
Globecar Revolution
Standard way to check is to jack up the suspect side wheel (not both)
Start car and put into gear and you can spin up the wheel and if the bearing is gone it will be ovious. Switch off any traction control if fitted.
Im asuming your are concerned about one of the front wheels on FWD car
You need to be confedent in what your are doing and have decent axel stands etc
Alternative as others have said noise should be difrent when turning on one lock campared to other with least noise when going in a streight line.
It can sometimes be dificalt to decide which side is noisey
Aug 26, 2008
4,763
24,982
B&NES
since 2007
A horrible noise stopped when the trapped stone that was rubbing against the brake disk eventually fell out.
A different horrible noise when cornering was tracked down eventually to a cracked ABS ring (uncommon).
Armchair diagnosis is stricky stuff.
Feb 15, 2014
713
1,249
cambridgeshire
Bessacar E450
3 years
if you can feel movement get someone to press hard and hold on the brake pedal and check for movement then check if no movement definately wheel bearing if still movement will be a joint
Leakylunar
Jun 17, 2019
478
620
East Yorkshire
Just looking
One a newbie
We’ll just been out, noise definitely worse turning left almost totally goes turning right!
So I’ll check for play on passenger wheels whilst brake is applied .
Sep 1, 2018
1,985
6,650
Strathaven
Pilote G741
Since 2018
Turning left loads right hand wheel so likely it’s the drivers side , you can usually tell by noise , if it’s the back or front
Sep 29, 2019
3,060
7,071
Hymer Exsis
20 years
You can normally hear if they are gone by spinning the wheel.
If there is play in it, and it isn’t from the suspension components, almost certainly.
