Heating and fridge not working on hook up . (1 Viewer)
Jul 10, 2017
1,065
2,905
Ireland
Coach built
Currently in Spain , 2023 Burstner , suddenly neither fridge or combi boiler working on 240v hook up . Rest of mains appliances are fine . Both appliances will work on gas . Any thoughts or help much appreciated. Campsite supply is 10 amps . Cheers .
P
Jul 10, 2017
1,065
2,905
Ireland
Coach built
Feb 24, 2013
13,133
101,667
Bolsover, Derbyshire
Hymer S800
not long enough
What can I do about that ? If anything . Cheers
Can you easily plug into a different post? We had a similar issue some years ago in Spain, different post no problem
Following morning my curiosity got me, I checked the incoming voltage with my multi meter, we only had 160V on original post, enough to run some things not others 🤔
P
Jul 10, 2017
1,065
2,905
Ireland
Coach built
Fridge now working on hook up ( after I turned the heating down for night time temp ) does that suggest drop off at post ?
P
Jul 10, 2017
1,065
2,905
Ireland
Coach built
Will switch to another output on the post tomorrow ( it has four ) and then a different post altogether . Cheers .
P
Jul 10, 2017
1,065
2,905
Ireland
Coach built
Can I just try another output on the post or a completely separate post ? Cheers , and btw people thanks so much for your help , invaluable 💡👍
Can I just ask , what causes low voltage at a post ?
53,984
152,117
Probably won't help unless you move to a pitch nearer to the incoming mains to the site..
Why worry about both the heating & fridge will work better on gas.
Shrimp
May 27, 2015
4,007
33,917
Bedfordshire, UK
Hymer B584
Long time
Fridge always work best on Gas, and surely you don’t need heating on!
An extra jumper or a rug over your knees!
P
Jul 10, 2017
1,065
2,905
Ireland
Coach built
We are away for 6 weeks ( NEVER been away this long abroad) and my worry was running out of gas ( 6kg Calor and 7 Kg Safefill ) I’ve got the adapters for the Safefill but no real idea where I can refill it in Spain ( led to believe I can’t use fuel stations )
Had a slight panic that if my leccy was up the spout I’d have no heating or fridge or van oven if me gas ran out !
Just as an aside does hook up cable length affect voltage drop off ? Cheers and thanx again .
53,984
152,117
Not for the fridge but it will if using the heating, also depends on the size or the cable in sq mm.
These are approx figurers for a 10 amp load, 25m cable of 2.5 mm sq 5v, or 1.5 mm sq 8v.
Sep 9, 2019
882
1,934
Runcorn
Autotrail Apache 632
Since Sept 2019
Voltage drop will occur with really long cable runs, doubt a 2.5mm 3core at 25m length will cause enough voltage drop to cause you problems; unless! the post you plugged in to was already on the end of a long run of cable! Not at home at mo but will have a look in my “On Site Guide” book when I get home and give you some idea.
Sep 9, 2019
882
1,934
Runcorn
Since Sept 2019
Voltage drop calculations are quite complex, they involve lots of factors. Basically the hotter the cable gets the less current/amperage can flow and the more voltage drop can occur. So this is a guide rather than a hard and fast definitive calculation. Table 4D2B in BS7671 18th edition wiring regulations, or Table F5(ii) in The On Site Guide, same set of regs, gives voltage drop for two-core cable, single-phase ac (basically as close as possible to what you use as a lead to connect your Moho to the electric post) for 1.5mm as 29mV/A/m, 2.5mm as 18mV/A/m. So translated into English 2.5mm cable will lose 18 millivolts per Amp per metre of cable. That means that for every Amp you use you will lose 0.018volts per metre. Therefore a 10metre 2.5mm core lead will lose 0.18volts over its length, if you are using 16Amps, the maximum the post can give you, the voltage drop will be 2.88volts.
If the post is supplied by a 25mm two/three core cable buried in the ground the figure for voltage drop will be 1.75mV/A/m. Let’s guess at a 100m run from supply to post at 16Amps. (1.75/1000)x100x16=2.8volts.
Total volt drop from supply via post then through your cable to the Moho will be 5.68volts.
SPEnergy Network state “In the UK, the declared voltage and tolerance for an electricity supply is 230 volts -6%, +10%. This gives an allowed voltage range of 216.2 volts to 253.0 volts.”
Mainland Europe is SUPPOSED to be in line with the UK, so if the supply started out at 230volts you should have around 224volts at the Moho, well within tolerance.
Hope that answers your question!
Cheers!
Russ
