Gasit Install! (1 Viewer)
Jul 26, 2015
296
193
Devon
Hymer
since 1999
Im thinking of buying refillable gas cylinders (GASIT) for the motorhome and fitting them myself.
Avon Autogas in bristol has a offer on for x2 bottles,pipework and external filler.
It seems very straight forward.
Does anybody have any advice?
Many thanks..
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
If you do fit your self get it checked by a proper gas person just to make sure.
Feb 16, 2013
19,735
52,035
uttoxeter
ambulance conversion
50 years
Many thanks..
Pretty much like changing a calor bottle to fit them but if you go for the external filler you need a hole in the body.
Feb 16, 2013
19,735
52,035
uttoxeter
50 years
I have seen this many times, where do you find these gas people that are qualified on motorhomes, and do you have to get them to have a look every time you change a calor bottle because it is just the same.
Sep 28, 2015
2,018
2,615
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
I fitted our first Gaslow bottle myself and thought I'd done a good job. When we changed to twin Alugas, Autogas near Thirsk fitted it for us and I was shocked at how tight they did up the connections with a huge spanner, his was much bigger than mine.
They pointed out how much pressure there is on the fill side pipe work.
Two on Tour
10,327
50,990
Elddis Autoquest 175
Since 2010
All you need is common sense, plan the positions, hose lengths and fittings you need and then double check what you have done when you have fitted it.
Like you I run a two bottle Gas-it system that I fitted myself but I also fitted a Gaslow change over gauge so I know when a bottle is running low and one of the other advantages of this gauge is that you can do a pressure leak test with it.
Theonlysue
6,104
7,383
Essex
Not long enough!
@chaser the op seems like he is having a go. Nothing wrong with getting a gas fitter to check.
This is a fixed system so nothing gets moved.
I'v seen external filling points fitted to the gas door and have pointed out to tbe dealer that this is what gaslow say specifically not to do in their fitting instructions.
Nothing wrong in being cautious.
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
Take your time with the install, don’t use to much sealant as this can block the fittings, and use spray leak detector solution to check all joints, DON’T use fairy liquid as it’s corrosive with stainless Steele.
John.
Feb 16, 2013
19,735
52,035
uttoxeter
50 years
Not knocking anything you said, but my question was genuine, where do you find a motohome gasfitter? I have no idea.
musson
487
165
grantham
low profile
since Jan 2014
I fitted the same system very easy just take your time use the correct gas testing spray on all connectors I did mine just before
i had the habitation check so it was checked when that was done well worth the cost,you will need a 70mm hole saw but all instructions are on website
Theonlysue
6,104
7,383
Essex
Not long enough!
Any safe registered fitter should be able to help.
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
Very easy to do ensure fittings are tight and when you do filler hole put masking tape over the outside that will enable hole cutter to stay center and also stop paint chipping. Good idea to connect filler hose to fill point before fixing it to van then you don’t risk it turning when fitted.
Minxy
32,659
66,565
E Yorks
Carthago Compactline
Very easy to do, certainly wouldn't pay anyone to do it for me unless it was an extremely difficult install which would be very unlikely! So far I've installed it in 4 MHs/campers without a problem, just made sure everything was connected-up and tightened correctly and that there were no leaks (you can get a leak-spray if you don't want to use the washing-up liquid method) - you need to make sure the connections are tight but do NOT over-tighten them otherwise you could strip the threads.
Minxy
32,659
66,565
E Yorks
John.
I assume by this you mean the hose connections? If so you shouldn't be using any 'sealant' or anything else on them at all.
Feb 16, 2013
19,735
52,035
uttoxeter
50 years
Compleatly agree, didn't want to argue with @Hettie's Crew in the previous post but I always thought it shouldn't be over tightened , that is the reason a proper calor spanner is short so you can't over tighten.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I fitted my own Gasit installation, I got a pair of hole cutters that they supply at a good price to work with dual skin exterior panels.
Sep 28, 2015
2,018
2,615
Hymer B544
Bottle to regulator should be tight but the fill side pipe work needs to be very tight because of the high pressure from the filling pump. Not my opinion, but what Autogas 2000 told me when they fitted mine. I think Calor spanners are used on Calor bottles because of the rubber seals in them, refillable systems use compression joints.
Feb 16, 2013
19,735
52,035
uttoxeter
50 years
No rubber seals in propane bottles just brass to brass, always puzzled me how it seals but it always seems to(n)(y):)
Neckender
3,221
5,921
Since 2004
I’m a retired gas fitter and I know this, but the amount of jobs I went to that the supposed fitter had used large amounts of boss white and blocked the fittings and pipe work.
A light smear on ground fittings does no harm, and another thing with rubber washers they only need fingertight then a pinch with a spanner or if overtightend the rubber washers push out and split and then no amount of tightening will stop the leak.
John.
Sep 28, 2015
2,018
2,615
Hymer B544
I've never had one with no rubber seal but they do appear to be brass to brass, has that changed, this is the one I was using up to swapping to refillable a couple of years ago.
Anyway, nothing to do with the OP, I wouldn't hesitate to fit my own, as I did originally. The only reason I had this system fitted is because they offered to do it for free when I went to get the bits.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The only DiY difficulty for anyone who isn't very familiar with spanners and fasteners is in developing the 'feel' for correct tightness.
Anyway, on a different subject, my tip for using hole cutters is to drill a small (3mm say) pilot hole before bring the hole cutter anywhere near bodywork. That way it cannot slip.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
This is the conventional POL fitting. Rubber seals incorporated in a variation of this seemed to appear when 'hand-tightened' versions appeared.
Broken Link Removed
bluesurf989
Jul 26, 2015
296
193
Devon
Hymer
since 1999
Wow thanks everybody for your input, Amazing as ever.
One on the things that does concern me is the original bulkhead regulator that would stay, i heard these can be problematic!
Two on Tour
10,327
50,990
Since 2010
I don't see why, it's the same gas (propane) at the same pressure so what's changed to cause them to fail.
I think the problems might be caused by people not turning off the bottles before filling at the petrol station pump as the pump pressure is very may damage the bulkhead regulator if the bottle are not turned off.
Sep 28, 2015
2,018
2,615
Hymer B544
I've never had one fail but when we bought our current Motorhome at one year old I noticed a sticker in the gas box saying a new one had been fitted.
We don't have a filter but if I'm right I think the advice is to loop the pipe down from the regulator then back up to the cylinder, so any contamination gathers at the bottom of the loop, or fit a filter.
Gaslow (R67) have filters in the them and I think Alugas are the same as they have the same valve assembly.
Oct 29, 2008
5,070
5,973
West Yorkshire
PVC
since 2008
No but if you have an accident causes by the installation and you had been negligent you would find you are not insured. You could also be done for manslaughter.
There are some people that are too incompetent to change a gas bottle! Ive seen them in action.
You should always check for leaks when changing a bottle.
