Aircon?? (1 Viewer)
bri
Oct 2, 2020
185
169
South Yorkshire
BENIMAR BENIVAN 122
Hiya, thinking about air con being fitted in habitation of my 6.36 van conversion,and wondered if anyone out there has done something similar and justified the cost.
Nov 8, 2019
397
3,133
Surrey
Since 2017
A definite benefit is you’re not carting around the excess weight of a built-in system when you don’t need it. Also, change your vehicle and you can take it with you. It won’t make the interior ice-cold but it certainly makes it a lot cooler, had no problems sleeping at the height of Spanish/France summers, nor did adjacent campers as runs quiet enough.
Jonno1103
1,336
1,482
Harrogate
F Line F70
We've had our Dometic roof air con re-fitted onto our last two vans. Even though it's not supposed to be for 7+metre coachbuilds, it kept our rear beds cold during two hot weeks in France last year - we just use the built in sliders to direct it to the living area if needs be.
Ours is fitted where the Omnivent sat and that unit was given to us as was the rooflight in the previous Pegaso and the same with the AT EKS. The dealer refits them as they move the AC unit.
Adds about 30kg to your payload and isn't as heavy on power as the Truma Aventa which needs a power boost on start up that can easily blow 6 amp EHU abroad.
One of the best accessories we've ever bought.
Jan 28, 2016
2,505
2,947
Stockport, Cheshire
Bravaria i740 AClass
We used to have a fiamma turbo vent. Poor mans aircon but enough to allow sleep in south of France in August heat.
Oct 26, 2014
1,887
3,226
Dumfries and Galloway
Pilote P696GJ
We have the Truma Aventa Compact fitted to our 6.5 metre Pilote , its works just fine on 6 amp hookup and never trips out the EHU even on start up .
We have used it on many French and Spanish Low amperage sites without issue
It was an absolute godsend in the 40c heat we experienced in Provence in July 19
gerrym11
181
298
Colchester, UK
AS Broadway FB
Just a year
I intend to buy the Aventa Compact when COVID restrictions ease. In the reviews I have read it is quieter than the Dometic which is key to me. I was looking at the 'cool my camper' a/c unit mentioned above but it just looks too much like hard work to me plus it blocks out visibility out of the window.
Shop around, I have found some companies that have special offers on fitting.
BillandHelen
862
2,191
Edinburgh United Kingdom
Wildax Elara
since 2004
We have had the Dometic Freshlight on previous van and specced it on our new one too. Replaces the central vent in our 7m panel van, allows light, and great for cooling van down in hot conditions. Personally wouldn’t be without it.
May 14, 2014
619
748
Now a little one
As post #6 we also have the Truma Aventa Compact fitted and can confirm it works without tripping low amp ehu's and keeps our 6m coach-built nice and cool. We also had it installed so it can run off 12v through a 2kw pure sine inverter for short periods if necessary.
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
If you want Air/con, you'll need to be on EHU.
Oct 26, 2014
1,887
3,226
Pilote P696GJ
Rhino Installs at Bamber Bridge fitted our Truma Aventa compact at a cost of £1700
gerrym11
181
298
Colchester, UK
AS Broadway FB
Just a year
I’ve just checked his website and fitted price is £1745 for the Truma Aventa Compact so it’s went up £45 since I had mine fitted
Apologies, you are quite correct, I was looking at the Compact Plus. I think I would want the extra 500W of cooling for the small price differential.
Oct 26, 2014
1,887
3,226
Pilote P696GJ
Gerry if your Motorhome is more than 6.5 metres I would say the Compact + would be better option and still only draws 4.4amps so still useable on 6 amp hookup .
Aug 18, 2011
12,160
18,029
derbys
AUTOSLEEPER SYMBOL
If its hot we leave windows wide open,,if very very hot sliding door is left open with fly screen pulled across,,(posh name for net curtain.) BUSBY.
TerryL
6,192
8,207
North East
Low Profile
I actually removed our aircon unit (which came with the van) 'cos in the 12 years we've owned the van we have used it "in anger" less than half a dozen times - it needs hookup to be able to use it and we rarely do campsites.
Replaced it with a Maxxair Maxxfan unit that simply fitted in the same place. Runs on 12v and can either suck or blow, at normal speeds is very quiet and the cover (clear, smoked or white) can be left elevated for ventilation, even on the road. Great as an extractor fan too, ours is over the kitchen and the smoke alarm doesn't go off now when I'm cooking Sunday breakfast!
Of course it does not cool the air but instead we find circulation is just as good, at minimum settings it's almost silent, great for warm nights.
Also bought the extra blind that includes additional LED lighting - total cost around £450. We had it fitted because the aircon unit was too heavy for me to handle in removing, but otherwise a simple enough job to fit. I sold the aircon unit for almost as much as I paid for the Maxxair!
In the 12 months we've had it, got used on every outing, which is twice the number of times the aircon got used in 11 years.
Jan 19, 2014
9,400
24,807
Derbyshire
Elddis Accordo 105
since 2014
We just use fans too. In the daytime it's in the window:
Then at night I put it in the ceiling, it really does blast lots of cooler air in off the roof. I fitted a 100w resistor with heatsink to slow, and quieten it down 😎 don't bother with an extraction fan they aren't anywhere near as good.
Then I made a 12v version with 120mm axial fans. I put a stat on it to knock it off if it gets cold, also speed control.
You really don't need aircon if you get sorted with the right fans 😏
Nov 6, 2008
3,944
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
We have had habitation A/C on all of our RVs, and to be honest we rarely use it. Much prefer to have windows open, or sitting in the shade outside. The fantastic fan does a good job if we need a bit of cooler air inside, plus you need EHU or a genny to run the roof A/C.
Craig
gerrym11
181
298
Colchester, UK
AS Broadway FB
Just a year
IME fans just move warm air around. You need a proper a/c unit if your requirement is to lower the temperature in your moho.
Nov 6, 2008
3,944
40,801
8 years with an RV
An A/C does reduce the temperature inside your MoHo admirably, but, when it is cooler, you are then confined to the MoHo to feel the benefit. Nice initially, but soon enough, the doors and windows will be open again. And as for sleeping with the A/C on, is not for me.
Craig
Jan 19, 2014
9,400
24,807
Derbyshire
Elddis Accordo 105
since 2014
I used to switch it on in the works van, one lad I worked with used to wind the window down and I asked why he did it, and said it'll be cooler with the window up. He said "it's summer, I like the windows down" 😁 fair enough
Jul 6, 2009
1,819
2,251
We have a Dometic Freshjet 2200 fitted in the bedroom of our Burstner A clasS &.5 mtr van. During the day if on site we run it with the vents facing forward into the lounge. Then use it to cool the bedroom in the evening. It works well we were in France during part of last summer with temp up to 28c. But it is too noisy to run when sleeping, and of course you are restricted to needing hook up, this unit will run on a six amp supply without tripping. When we can move are having 400 watts of solar added to our 100 watt panel, an inverter charger and 200 amps lithium fitted which will allows us some limited use when off site.
Jan 19, 2014
9,400
24,807
Derbyshire
Elddis Accordo 105
since 2014
Why do most people think air con only offers cold air? They also offer filtered, dehumidified warm air too.
Yeah that's a biggie for me, at home I put ours on Dry mode in the summer, you immediately feel more comfortable even though it's still hot. 👍
