A Motorhome tracker you'd be stupid not to fit. (2 Viewers)
Status
Not open for further replies.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Having not read the whole thread forgive me if this has been covered.
If the tracker only wakes up when you contact it or once a day for a few seconds to report its position then it is flawed from the start.
I would suggest it needs to alarm the owner if it has moved unexpectedly. Otherwise one could find themselves with a motorhome reporting its location in deepest darkest Romania. Would that not cause more problems than it solves?
Jim
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Yes you need to read the thread and see how we come to that. That is one of the reasons for having two trackers.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
After reading a bit of the thread I am still confused. One would have a "sacrificial cheap" tracker and a " motorhome tracker you would be stupid not to fit" tracker.
The "motorhome tracker you would be stupid not to fit" tracker would wholly depend on the " sacrificial cheap" tracker to detect the theft of the motorhome in the first instance? BEFORE being found and sacrificed.........I'm very confused.
Chris
21,053
278,728
10 years
The "motorhome tracker you would be stupid not to fit" would wholly depend on the " sacrificial cheap" tracker to detect the theft of the motorhome in the first instance???:crying:I'm very confused.
So am I after reading that:rolleyes:
Jim
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Have a simple tracker wired to the battery and you can check it’s real time location anytime you like. Brilliant, However, in the event of a theft, because it is reporting in every few seconds, there is a good chance it will be found and discarded anyway so maybe not so good.
Have a well hidden tracker with its own power source and have it report in once a day, (any more frequently than that you run the battery down) this one will not be found. sounds great but could mean your pride and joy is 24 hours away before you notice it is stolen. So not so good after all.
By fitting two, you have the best of both worlds, the “always on” one you would use to check on regularly, whenever you want peace of mind. Then if your van is stolen, even if the 12v tracker is found and discarded you can, on the same map, see the well hidden one. you can send messages to it and ask it to report more frequently to track it.
39
19
Van conversion
Jim. The van I'm buying (IH 630RD) offers a Thatcham approved Autowatch track and trace tracker.
£310 to install and £150. subs. no doubt the sort of package you are attempting to better.
Money aside do you put the Autowatch technology in the traceable category
Nov 28, 2018
39
19
Van conversion
New to the forum and had not followed the extensive posts on this thread, more reading required but I think I have the gist of it.
The insurance angle may be a determining factor.
Great thread BTW
Jan 19, 2014
9,390
24,773
Derbyshire
Elddis Accordo 105
since 2014
Why not hide the first one better? Putting ours behind the fridge vent. Let's face it, If you haven't found the van in the first few hours (parked up somewhere), you're not going to.
You can send the tracker a text telling it how often you want it to report it's position so it's totally up to you.
Jim
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Thats true, unless you have a power independent second tracker telling you where it is.
Jim
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
That may well be all you need to do. However a £5 detector from eBay has a good chance of finding your tracker and a £25 one will find it. Which for me is why having the second deep sleep tacker installed makes sense. Their detectors are not going to find it so if my van gets stolen my chances of finding my van are much higher.
39
19
Van conversion
I fear this debate is undermined by readily purchased multi signal jammers.
No need to find the tracker, just jam it.
You might know these thieves unlike us are doing it for a living and have all the time needed to dig up the technology they require to thieve our stuff.
So it looks like I will get an insurance friendly tracker and get on with my life.
Worrying to see the devious measures that are out there and I am guessing I will switch to physical and visible security.
Check this out. http://www.jammer4uk.com/high-power...-all-bands-adjustable-signal-jammer-p-50.html
Bobby22
1,537
6,408
Rapido 680ff
since 2013
I reckon you will have to have a very long extention lead, if your going to use that to jamm a motorhome tracker signal. It runs off mains electric:D:D:D
Oct 2, 2014
585
1,726
West Yorkshire
Rapido 866f
Since 2014
Insurers happy, oh are you the optimist.
If all they demand is a Thatcham alarm fine. You'll just have to ask them. Which will illicit "this guy can afford a tracker, might as well insist on one".
Surprisingly they don’t need an alarm.
Rang Comfort and because it is under £55,000 they don’t need anything other than the immobiliser that is Peugeot factory fitted.
I’ve just booked into Vanbitz for a Stikeback regardless of that. In fact I still can’t quite believe it.
May 29, 2013
2,597
19,230
Tyneside
Chausson best of Flash 10
Several years now
Just wondering what became of the tracker idea?
Aug 5, 2018
1,567
3,513
a
What they fail to tell you if yours gets stolen by a more professional outfit, is they will sweep the van with a detector and find both no matter what you do.
Jan 19, 2014
9,390
24,773
Derbyshire
Elddis Accordo 105
since 2014
Not ours :cool: it shuts down a few minutes after the ignition goes off but the location remains on the map :cool:
PS And even when it's on it only transmits briefly every 5 minutes (y)
Jim
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
The guy I chose to work with on this has come up with a good system but administration wise he has proved to be pretty unreliable, I'm using the system on my RV and Landrover and it works extremely well. I'm just not happy to recommend it right now because I feel customer care would be lacking and that would reflect badly on me and cause me issues.
Development in this area is fluid. Someone showed me an asset tracker the other day that reports once a day for 7 years before a battery needs replacing and it's likely to be sold for less than £50. I'm sure that we'll be able to recommend the best solution soon.
Doozer
45
23
Spain
Hi Jim, are there any updates regarding the asset tracker you mentioned in your last post?
Vic. Parsons.
415
1,970
Wales
Hymermobil S740
since 2014
If they're so easily found, why not also try to fool the thieves by having a second cheap tracker which they can find easily and without damage to the interior, and the real one being a stealth version that pings every hour or two with a micro burst that's difficult to detect.
Then the thieves will think they have the tracker out and be caught in the act. ?
Status
