autoswan
The mrs used the cold tap fine then a minute later nothing ! pump not making noise to show its on anymore ?
I checked fuses in control panel are ok
Were on hook up at the moment on a site on Ile De Re France.
There are 2 switches in wardrobe for hot water i think
The boiler feels quite hot as if its full of hot water so i switched off the 2 above pic for now.
The boiler has no obvious fuses showing unless i have to pull off the small triangular lid just above the wire on pic ?
The pump has a plastic cover over i think is a filter it dripped when i unscrewed it a little.
So any ideas what i can try to get it going again will be appreciated, many thanks Jack.
