Urgent help (2 Viewers)
May 31, 2015
11,724
44,665
Ducato PVC
Getting Better
Can anyone tell me correctly what oil my 2012 fiat Ducato 2.3 150bhp comformatic takes I'm stuck at a shell garage in limp mode with no oil in the engine...
irnbru
13,515
31,144
Glasgow
Benimar 264
11 yrs
Wow that was a quick response from @Robert Clark . (y) Hope you haven't caused any engine damage.
Jun 30, 2010
7,925
27,239
1992 VW Auto sleeper Mono
Since 2005 this time
Can't see Semi Synthetic doing any harm
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
Ace, love this forum! Hope you havent cooked your engine!!
Billggski
114
63
Stone
Overcab
The Fiat handbook for my 2015 Ducato recommends SAE 5W-30 ACEA C2 grade synthetic base lubricants. Classification FIAT 9.55535-S1.
Oct 6, 2016
507
776
norfolk
newbie
5/30 fully synthetic,,,
What you really need to know though is WHY/WHERE the oil has gone,?!
If there's no red lites on the dash the engine should be ok, but there is obviously a leak,,,
get some oil into it and then do a thorough check from the bonnet and beneath the engine while it's idling.
Make sure to check the dash when you start the engine,!
Good luck.
PP Bear
7,832
28,891
Kent, UK
Auto Trail Dakota SE
Mobil 1, it's excellent in every way 0W-40. Used it for year in all my engines and the results are noticeable. Worth considering:)
Feb 16, 2013
19,758
52,140
uttoxeter
ambulance conversion
50 years
I would the think the first job is finding out where it's gone, before your new oil follows it.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Logic says ... anything will do (oil wise)... DPF or no DPF... BUT only until... you know what you need.. and can get it sooner rather than .. like nxt yr!!_
Just smiffy
May 31, 2015
11,724
44,665
Ducato PVC
Getting Better
Well....... so, today is only the second day it's been driven, picked it up from littlehampton last Thursday drove down ok, (near Truro)I had my temporary hand controls on... today drive to South Molton to get permanent hand controls on.... on the way back getting dark and foggy lights on and I can now use cruise. Driving for about half a hour I get a warning come on, red symbol (now known as transmission) and saying check transmission I notice that the glow plug and oil light are on..? Very dim but on..? Turn off cruise and there still there. Engine has little power.
I pull over at first available stop and turn off wait, and start up and it comes back on.... I turn off and have a look at engine all looks ok but no oil on engine dip stick..? I know a garage not far and wait for engine to cool and drive to garage with heating on full van haven't much power...
Get to garage and my first post, I buy 5ltrs of 5/40 fill it... it's now showing on dip stick and no sign of leaks anywhere, I then drive 60 miles home like nothing ever happened..!! Runs like a dream but oil and glow plug lights dim but still visible.... pull on to drive and transmission warning light comes on just as I'm about to turn off....
It had mot and a service five days before I picked it up...
It's a fiat ducato multijet 150 comformatic
Will have a look tomorrow in the light but will probably take it to a fiat garage..(n)
17,641
43,436
if its just been serviced, suspect the sump plug or oil filter are not tightened or cross threaded
Silver-Fox
9,278
29,173
Cheltenham Spa
Rapido
im a not so newbie
If it is the sump plug the under tray, if it has one, will be well damp with oil.
Probably will have misted some of the under carriage as well.
Wasn't there a post about using cruise and some warning lights coming on before on here?
Good luck sorting her, if it is a cross thread you may get away with helicoiling it.
Feb 16, 2013
19,758
52,140
uttoxeter
50 years
If it's been driven without oil , I would seriously be getting it looked at , and sending it back, we are all on about it having the wrong oil , but none beats all that.:(:(
Jul 5, 2013
11,734
13,720
Garry, the dim warning lights are a known fault on Fiat dashboards. They were the same on mine and I got a replacement instrument cluster under warranty. As I understand it many people have persuaded Fiat to replace the cluster even if it is out of warranty, because it is a known fault. Suggest you take it to a Fiat Pro dealer to see if he can sort it out.
Oct 29, 2008
5,076
5,987
West Yorkshire
Either the mechanic didn't fill it properly, some engines the dipstick level changes a short time after filling or you have a leak.
As others have said you also possibly have a faulty dash cluster.
Aug 11, 2016
353
1,145
ipswich
Not sure
1 year
Has the dipstick got a small plastic sleeve on the bottom that could have gone missing. I would be phoning the guy who serviced it and ask him why it was not filled properly and making him aware that any damage caused by his work would be down to him to repair.
Just smiffy
May 31, 2015
11,724
44,665
Ducato PVC
Getting Better
Update.... the van is on a slight forward incline on my drive and oil is showing on the dip stick at an appropriate level, I have got the under tray off and it's as clean as a whistle under there.... no leaks... I will put the undertray back on and give fiat a call...
Fletton
1,531
2,501
Lincolnshire, UK
Hence my post about anything being better than nothing.. (y)
Aug 18, 2014
23,842
134,291
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
As in the garage that just serviced it ?
Oct 7, 2013
5,908
37,046
South Wales
Swift Escape Compact
Since 1988
@Smith and Sharp
We have also had the problem with the instrument cluster.
Turn on cruise control and several warning lights illuminate at about half-strength.
If you get warning lights then, which go out when you disengage cruise, you have the faulty instrument cluster problem. It may be nothing to do with oil loss. That is better checked by filling to level then watching how quickly the level drops.
In your initial post you said that you were at a garage with no oil in the engine. Did you know that from dipping the oil or were you going on the illuminated warning lights?
