Tyre Pal Sensor Leaking? (1 Viewer)
Feb 15, 2016
647
1,073
Since April 2016
Having gone 18 months without having to inflate our tyres, a few weeks ago one of the back tyres pressure dropped 10psi over 5 days staying in one place. I pumped in back up and on the way home over 2 days it went down 4psi. I could see nothing in the tyre to suggest a puncture. The tyre pressure then stayed the same over the next week.
Having bought a 12V extension lead to make topping the tyres up easier, I then topped up all the tyres.
2 days ago the other rear tyre was 10psi down, I topped it up and this morning the same tyre was 10 psi down again.
As this problem is now on a different tyre, I wonder if I could have swapped the sensors over without realising? Has anyone had a problem with a leaking sensor?
May 17, 2016
3,639
7,880
Aberdeenshire
B524
2nd base
They can sometimes cause a leak. I'm wondering if mine is letting down my near side front.
They are marked though so shouldn't be getting them mixed up.
Buy yourself a tin of leak detector spray and look carefully as it won't be a steady stream of air being released.
Great bit of kit when they aren't deflating your tyres.
Jasz
Feb 15, 2016
647
1,073
Since April 2016
I had forgotten about them being for set positions, it isn't that then as it is the correct tyre that has gone down.
Jasz
Feb 15, 2016
647
1,073
Since April 2016
It looks like they came with a spare set of rubber washers - probably worth trying to change the one that is possibly leaking.
Aug 12, 2021
669
1,522
Nantwitch Cheshire
A Class N+B Flair
25years
I use gas sealant no problems over many years.just a little on the threads and it’s flexible.
3,759
10,473
1995-2004 & 2017》
As Jasz says... once you remove sensor you can damage very small rubber seal.
I always have spares and replace regularly.
Jim
Ringleader
Jul 19, 2007
36,688
132,675
Sutton on Sea, UK
Adria Panel Van.
Since 1988
They caused a leak on my RV the first time I used them, insde rear as well, what a pain.
Apr 3, 2018
3,759
10,473
1995-2004 & 2017》
Where did you get the spares?
Tyrepal don’t seem to sell them separately?
Oh... sure I bought seals( big And small) And batteries direct from Tyrepal.
54,124
152,789
I had one tyre that was losing a few PSI a month, it turned out to be the metal valve slightly loose in the rim. Due to their construction they are easy to tighten don't need to remove the tyre.
Sep 10, 2017
427
964
I just use them as dust caps and don't have any issues or leaks. I still get a pretty accurate reading.
I got fed up mucking about when topping up the tyres and the gradually various bits perished.
After few thousand miles one did work a bit loose and give a dodgy reading but I tightened it up and its been fine since.
May 12, 2019
545
795
Tyneside-Cadiz: All points between!
Autotrail Delaware
Years Tugging - Newbie MHing
Tyre pal are a PIA. I removed mine in August having been on after maintenance for less than a year, and found 3 of the lock nuts were ceased on and removing them buggered up two metal valve stem threads!
Using them was a nightmare anyway, loads of false over/under pressure warning so pretty useless really.
I discovered that during removal the sensors, in some instances, loosen the internal valve core slightly. That allows air to pass and when the sensor is replaced, it does not retighten the valve core.
Check the core tightness before refitting the sensor.
I’ve binned them all and back to plain old dust caps.
Apr 3, 2018
3,759
10,473
1995-2004 & 2017》
My experience totally opposite to yours.
Had mine on for 5 years and only remove once a year to manually check pressure (obviously more if Tyre pal says I have pressure issue) and change batteries. !!!
May 30, 2019
722
1,042
Aberdeen, UK
Adria Twin Supreme
Since 2018
One of mine kept losing a small amount of pressure. Installed them on my new van, and work perfectly. I’ll admit it’s a bit of an extreme way to check so you could just swap the one you think is leaking for a good one, that will tell you if it’s the sensor or tyre/valve.
May 19, 2020
205
248
Knaus Sun Ti 650 MEG
Since 2020
I had a leak when I removed the Tyrepal sensor, somehow not blaming the tyre fitters of course the valve was loose in the stem,perhaps unscrewing the sensor had in itself unscrewed the valve. I now keep the relevant valve spanner with me in the van, thankfully at the time I was at home and I had one in my bike toolkit.
Nov 8, 2019
398
3,157
Surrey
Since 2017
Exactly the same experience. I wasn’t even aware that the pin in the tyre valve unscrewed! Tightened that and problem solved. Wouldn’t be without mine, money well spent.
Apr 3, 2018
3,759
10,473
1995-2004 & 2017》
I am sure some of yoos auld foggy's will rmbr the metal valve caps that actually had a double prong to unscrew the internal valve mechanism. !!!
Jasz
Feb 15, 2016
647
1,073
Since April 2016
Although I still don't know why the first tyre lost pressure, I have now discovered that the second one had half a screw in it that wasn't visible and had barely reached the inside of the tyre. Having removed the TyrePal sensor it was still losing pressure so I took it to a tyre garage for investigation (Sorted now).
Jan 1, 2018
20
9
Cheshire
Adria Coral 670 DL +
since 2017
I had both rear valves come loose, I also carry a vale key in case it happens again.
Jasz
Feb 15, 2016
647
1,073
Since April 2016
The most useful things I now carry are a pump and a 15A 12V extension lead as the one on the pump isn't long enough to reach the 12V socket.
May 23, 2015
133
206
Weston super Mare
Van conversion
Since 1992
I had the same problem had to call out recovery while on holiday so gone back to caps
EMS
Jan 8, 2010
200
181
Hants Sussex border near
Coachbuilt Low
Started 2009!
I have used them on several vehicles for many years with no problems, just change the batteries.
Then I had one tyre that slowly lost pressure.
I contacted TyrePal by phone to order some spare washers that were not on their website, they apologised and supplied them and this has cured the pthe leak.
Calamaster
166
238
Surrey, UK
Autotrail Cheyenne 6
Since 2017
I had this same issue. It turned out the Valve thread was a bit 'cross-threaded' and the sensor seeped a bit. Replaced and all tested good.
You could have a leak from Nail or something. Washing up liquid and water dowsed all over will reveal bubbles from tiny Air leaks.
