Swivel wheel Trailer (1 Viewer)
Betsy Lamb
22
26
Hi,
I have seen some trailers in France with two ball hitches, effectively a non articulated trailer. These must be easier to reverse (not that I have a problem with reversing) and are shorter than a trailer with the A bit at the front. i think some have swivel wheels which turn around when being reversed.
Has anyone come across anything like this in the UK?
Are they legal?
where can I get one?
How much do they cost?
Thanks in anticipation
Ian
Betsy Lamb
Betsy Lamb
22
26
OK, searched for easy lifter. I recognise that I am dim-witted but I can't find one with wheels. I want something which bears its own weight as i don't want extra load on the rear axle.
Betsy Lamb
Betsy Lamb
22
26
found some with wheels (told you i was a dunce!)
Are they any good?
Dec 12, 2010
5,412
21,565
Cumbria
The biggest failing with a lot of them (IMHO) is that they don't incorporate any suspension into the design. There are a few notable exceptions, mostly French but they do command a premium.
Vic
Aug 1, 2010
461
536
Look for Easy Lifter Hydra Trail. Cost about £1200, occasionally come up for sale on here for £600 - £1000.
The French ones are about £3, but have suspension.
Oct 7, 2013
5,894
36,913
South Wales
Swift Escape Compact
Since 1988
The Hydra Trail has a form of suspension.
The pantograph, connecting the trailer to the vehicle, moves in the vertical allowing the trailer to ride over bumps. This smooths out the ride much more than rubber suspension does.
Last year we did over 2500 miles towing ours.
It is expensive compared to standard A frame trailers but It makes reversing as simple as if no trailer was present.
11,953
16,570
Really? You must be one in a million :D. I haven't found anyone who can reverse a short, invisible, trailer with any success. I regard unhitching as failure so I can reverse. However I'd prefer no one's watching unless they have a sense of humour.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Make that two in a million :whistle: All that's needed is a reversing camera and then it is straightforward.
Tell that to the crack in the rear valance!. And that from a guy who was a dab hand with 45ft and 18wheels!. It`s easier to reverse a 32ft R-V towing a 15ft Bed trailer!.
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Seen some of these trailers now without swivel wheels as well.
Can anybody that has used one say what they were like to reverse (either type) ?
I notice on the French (YO Remorques) that they have a rigid bar that needs installing when you reverse, seems a right faff if you have to do that for each manoeuvre.... as it says you have to remove it for normal driving.
Jan 13, 2014
3,601
11,585
Leeds - Yorkshire
YO Remorques are a well designed piece of kit and easy to load and you only need to fit a bar to make the Trailer rigid which simplifys reversing,not cheap but you get what you pay for, I’ve attached a link but they also do one that loads differently if you check out their website.
Nasher
2,094
7,179
Pontardawe
Pug Boxer
Don't mess around with trailers/easylifters/swivels/etc
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Like this:
And this was my concern, steering such a small trailer that you can't see that is articulated:( i'd total that in about 5mins.
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
And those that have swivel wheels like the Yo Remorques have a fixing bar that you need to remove/add each manoeuvre(n) and as far as i can tell they are also articulated otherwise.
Jul 24, 2009
4,330
104,514
South Yorkshire
Since 1999
The Hydratrail has swivel wheels and does not require a stabiliser bar to reverse. They do need a very strong motorhome chassis though due to the twisting forces exerted.
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Yes i notice on their website the attachment onto the single tow bracket is more of an arm which i assume doesn't allow for any articulation and hence easier reversing.
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Use a reversing camera and it's just like any other trailer - just need to be careful with corrections when you're reversing.
No way i'd manage with one set up like that, not unless my drive was about 1km wide
43,329
49,446
Some can reverse a car on an A frame..... Or so they say.
The distance from the wheels to towball, the moment arm, is too short and the vans overhang is too long to be unsensitive to the slightest movement.
Yes, it could be reversed as in the video.... But I could have unhitched and pushed the trailer far quicker AND SAFER.
Jan 13, 2014
3,601
11,585
Leeds - Yorkshire
So it's a regular trailer, just side loading. (y)
Impossible to see, impossible to reverse.
What’s to see! How many Motorhomes do not have a reversing camera and this includes Vans and Trucks the driver knows how long the vehicle is and uses his mirrors accordingly and his knowledge of the vehicles length, if you can’t see the type of Trailer we are discussing here you add the 1metre or whatever in your calculation of the vehicles length.
I realise there are confident and non confident drivers along with varying ability but drivers with shortcomings are basically defending their lack of ability and confidence to actually meet what should be the norm.
43,329
49,446
I think four years driving recovery spec frames of all sizes recovering, and reversing, everything from Aixims to large motorhomes qualifies me to decide what's easy and what isn't.
Vic
Aug 1, 2010
461
536
I have a HydraTrail and think it's brilliant. It uses the motor home tow bar, but the normal towball is removed and a bracket with a square home running it's depth is bolted on, using the original towball bolts in it's place.
The bit of the HydraTrail that attaches to the bracket is also square and slides downwards into the bracket. The HydraTrail does not articulate. The two rear wheels are on swivels. When reversing, the wheels rotate after a short distance and you can reverse as if it is not there. If you can reverse a motor home, then you can reverse a motor home with a HydraTrail. That is the main advantage of them.
Jan 13, 2014
3,601
11,585
Leeds - Yorkshire
And yet if you can’t see the back of it you can’t reverse it.
