Sapper520
I paid Amazon £285.18 including taxes and delivery. American ticket inside shows $325.99, so definitely saved myself a lot of money by ordering in from the USA.
have you had them fitted? if not where do you live? Happy to fit them for youSaw that, but hoping to find a company that will supply and fit......at a reasonable cost. I’ve emailed a couple of Towbar / Air Suspension companies to ask, but had no reply.
i have the other Mini hecki to do in the afternoon. ;-)A doddle to fit in no time, so you need to plan some extra things to do to fill the rest of your weekend.
For those who have fitted the Sumo Springs, did it make much difference to the ride etc. Still undecided whether to try these or install air assist, but I want to do somthing in the next couple of months.
Thnx
Literally just had a response from Van weight Engineering regarding Sumo Springs. I want to do something to the rear to allow me a bit more weight on the rear axle. Dee from VWE will not sign off any additional weight on the rear axles if I fit Sumo springs as he doesnt have the technical info from the manufacturers. So looks like Ill be messing about with feeding air pipes & drilling holes which was always Plan A.
He also mentioned that "some" people in UK who have fitted Sumo springs to their vans have failed the MOT. So another reason not to go down that route for me anyway.
I spoke to my MOT station last year and confirmed as ’as long as they have been fitted correctly he would pass the Sumo spring assist ours, they are basically a quality bump stop’ so wouldnt believe what Van Weight engineering are telling you, I suspect they want to sell you some expensive air suspension!Literally just had a response from Van weight Engineering regarding Sumo Springs. I want to do something to the rear to allow me a bit more weight on the rear axle. Dee from VWE will not sign off any additional weight on the rear axles if I fit Sumo springs as he doesnt have the technical info from the manufacturers. So looks like Ill be messing about with feeding air pipes & drilling holes which was always Plan A.
VWE did say “some”owners had problems with MOT so that means a lot probably didn't.I spoke to my MOT station last year and confirmed as ’as long as they have been fitted correctly he would pass the Sumo spring assist ours, they are basically a quality bump stop’ so wouldnt believe what Van Weight engineering are telling you, I suspect they want to sell you some expensive air suspension!
the job for this weekend is to take my Sumo Springs OFF. i have fitted air assist to my last van and thought i would give Sumos a go. the ride is far to harsh. even little bumps would go straight through chassis and shake the van. so off with the smo and on will go air assist. that is my humble opinion.For those who have fitted the Sumo Springs, did it make much difference to the ride etc. Still undecided whether to try these or install air assist, but I want to do somthing in the next couple of months.
Thnx
How did you contact van weight engineering? I have emailed and used their Facebook page but have not had a response on 2 enquiries.Literally just had a response from Van weight Engineering regarding Sumo Springs. I want to do something to the rear to allow me a bit more weight on the rear axle. Dee from VWE will not sign off any additional weight on the rear axles if I fit Sumo springs as he doesnt have the technical info from the manufacturers. So looks like Ill be messing about with feeding air pipes & drilling holes which was always Plan A.
Still working fine on the front of my EuraMobil integra. Mot soon so I’ll see if they comment on them.Any updates on those of you who have fitted Sumo Springs recently?
Passed mot fine & no comment at all.Still working fine on the front of my EuraMobil integra. Mot soon so I’ll see if they comment on them.
Fitted November '22.Any updates on those of you who have fitted Sumo Springs recently?
