Solenoid valve for grey waste. (4 Viewers)
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Why not consider using a plastic one as used on professional irrigation system - 12v and not only a lot lighter but a heck of a lot cheaper depending on supplier less than ÂŁ50
Dec 12, 2010
5,414
21,581
Cumbria
You would need to fit some kind of support bracket to it, especially if it's dangling on the end of a length of plastic pipe, it'll be a fairly heavy unit.
Derbyshire wanderer
1,288
2,390
Derbyshire
15 years
I'm looking at fitting the following valve to my grey waste,
http://www.solenoid-valve.world/by-material/brass-solenoid-valve/brass-solenoid-valve-AD40
has anymore fitted this type rather than the electric ball valve type? The outlet is 11/2" which makes fitting the ball valve system too bulky.
Far too expensive and it won't work as any bits will stop it sealing shut.
I got a 3/4" motorised ball valve off eBay for ÂŁ22 delivered and sourced the pipe adapters to fit (3/4bsp but 30mm did the job).
The motorised valve is controlled by a 3 position switch so I can set the opening to any flow rate.
I think they are about ÂŁ30 now delivered but still a lot less than the solenoid you have suggested
Charlie Farley
Charlie Farley
48
54
Powys
Dethleffs I7150
Sounds perfect, do they do them in 11/2? If so would you have a link to the website?
Derbyshire wanderer
1,288
2,390
Derbyshire
15 years
Derbyshire wanderer
1,288
2,390
Derbyshire
15 years
As seen they will fit the standard waste pipe. I ended up turning down the spigots from 30 to 28mm
Charlie Farley
Charlie Farley
48
54
Powys
Dethleffs I7150
The problem is I don't want to reduce the pipe work(it's 11/2 for a good reason)
Charlie Farley
Charlie Farley
48
54
Powys
Dethleffs I7150
The problem is I don't want to reduce the pipe work(it's 11/2"for a good reason)
Charlie Farley
Charlie Farley
48
54
Powys
Dethleffs I7150
I would simply replace the existing ball valve with the electric version and make an additional bracket to support the extra load.
Derbyshire wanderer
1,288
2,390
Derbyshire
15 years
I rechecked mine and it is 1" not 3/4".
The pipe is 28mm so 1 1/2" is approx 38mm while the 1" at 25.4mm is not going to restrict it much.
Some vans do use the bigger waste pipe but this has been on for 2 years now and never needed touching.
Just seeing your photo - could you fit a servo to the operating rod and leave the pipe work standard?
53,448
150,066
CAK Tanks do a range and they will be able to advise on the correct one for your waste system.
Are these for dumping 'en route' ? Or just convenience
Convenience, they should be wired with a relay triggered by the alternator D+ terminal so they can't be opened with the engine running, that's how it's wired on my Hymer. If you fit a service camera you can dump the waste without moving from the driving seat.
Charlie Farley
Charlie Farley
48
54
Powys
Dethleffs I7150
@Lenny HB I've spoken with CAK tanks who currently have issues with their easy flow valve(my first choice) I am waiting to speak with the technical expert as they don't show 11/2" listed on their website or online shop. Do you have any photos of the install?
53,448
150,066
Just had a look under the van, it's all built inside the insulated enclosure that houses the waste tank, just the drain pipe visible.
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
What's the issue about reducing the outlet ID ? It will only reduce the flow rate and therefore take a few seconds longer, nothing else.
Nov 2, 2014
331
295
Maldon Essex
I got a 1" motorised ball valve off eBay for about ÂŁ16
Plumed in as a extra so still has the 1 1/2 tap in place.
And it maintains the full winter use.
Also the OP valve is pilot operated and needs a small amount of pressure to operate.
Charlie Farley
Charlie Farley
48
54
Powys
Dethleffs I7150
@hchris now I hadn't considered that That's why I love this forum. Lots of clever lateral thinking people
Mar 16, 2016
1,072
6,601
Hymer S520
I'm looking to buy and fit one of these in place of the manual switch on my grey waste.......
Operated via radio control. Has anyone any knowledge of this item?
Pete
Alan47
4
Lancaster, UK
Hymer B544 PL
3 years
The motorised valve on our Hymer B544 has failed, has anyone experience of removing the outer casing that surrounds the grey water tank?
It looks like there are two metal support straps that hold up the outer cover, that will have to come off to fit a new motor valve.
Alan47
4
Lancaster, UK
Hymer B544 PL
3 years
Hi Lenny, yes, there is an access door, I will attach a photo to show the problem. You should see the valve there, with the backplate of the actuator still attached. I dismantled the actuator in place, hoping to get it off without removing the valve. However the actuator is fixed to the valve by three caps screws that screw in from the back, they are not going to come off while the valve remains in place. The discharge pipework is screwed into the valve, so that will be easy to remove, then the valve is screwed into the grey water tank. There is not sufficient space to rotate the valve and actuator so I think the whole cover will have to come off. I have considered simply fitting a manual valve in the discharge pipe, which I will do anyway in case of future problems.
For interest I have attached a photo of the mechanism showing the failure, my guess is that the limit switch did not stop the valve and the force from the gears was sufficient to break the plastic, I see something that should be an easy job turning into a project.
53,448
150,066
Thinking about on mine it says the hatch is to enable you to operate the valve manualy if the electric one fails.
I've got to take the stapes off on mine when we get home damaged the enclose on a kerb. One but & bolt at each end to remove.
See here.
