- Sep 23, 2013
- 2,585
- 8,790
- Globecar Campscout
- Since 2008 (started in a VW T4 campervan)
I'm just planning the fitting of a couple of solar panels. Most of the posts on here relate to fitting panels to a traditional motorhome with either an aluminium skinned roof or some variety of plastic.
I have a PVC on a Ducato Maxi van, so the roof is painted steel, with longitudinal ridges. The tops of the ridges & the bottoms of the valleys are flat & a couple of inches wide, but that suggests mounting brackets on the long edge of the panels running front to back on the roof, not crossways across the panel ends as a lot are on flat roofs.
Brackets on the ridges or in the valleys?
Just adhesive? No screws? Just clean the paintwork or key it?
Then the scary bit - where to drill the hole to bring the cables into the van? The largest flat area is where the main roof panel joins the over cab area to the front, & the side panel pre-prepared for attaching roof bars or an awning. That's just behind the 'B' pillar too, so a handy place to drop the wires down inside. I was thinking the wires could run behind the plastic cover where the seat belt is in the photo.
It's a Globecar Campscout, for anyone that knows the interior layout.
Any thoughts from those who have done this? Anything else I ought to be thinking about?
