Solar Panel, Inverter and Battery to Battery Charger - Deal or no Deal? (2 Viewers)
R
Robert Clark
I just got quote from Vanbitz as I'd like a solar system.
1 qty 100W solar panel c/w MPPT regulator, Battery Master and including installation @ £494.10
Dometic CombiPower Inverter/Charger (2000W inverter & 100A charger) @ £1,349.10
Installation of inverter/charger (capped 2 hours) @ £120.00
Parts and consumables for above upto £135.00
Sterling 50A Battery to Battery Charger @ £305.91
Installation of battery to battery charger (4 hours) @ £240.00
Parts and consumables for above up to £135.00
Total £2,779.11 (including 10% Funster discount)
Is this a good deal?
Have you bought better (like for like)?
Regards
Robert
43,329
49,444
2000watt inverter will draw 166amps/hour at its full potential......Hope you have a large battery bank as one 110ah battery will only last twenty minutes.
100watt panel will only give you around 6 to 7 amps per hour of good sunshine.
I would skip the very expensive inverter in favour of more batteries and a much larger panel....or a few smaller ones.
R
Robert Clark
Hi Pappajohn
Appreciate your comments
We've got 2 x 115 AH leisure batteries
Our biggest power requirement is a Nespresso coffee machine that uses 1200w for about 5 mins at a time.
We've also got at 250w towel rail that runs for 2 hours max, and Mrs C's hair dryer that uses 1700w for about 5 mins too....oh and there is a toaster which uses 750w for 5 mins
Hot water, kettle, heating and cooking (BBQ) runs off LPG
Regards
Robert
43,329
49,444
The towel rail is going to eat 41a/h over 2 hours...or 45% of your available power reserve.
To me its a luxury you cant afford in a motorhome unless you only use it on hookup.
Towels pegged across bonnet or on a purpose designed window towel rail will dry in no time if its sunny.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Save a grand for starters with one of these instead. Normal claimed output of 100 watt panels is under 5 amps and you won't get most of that most of the time.
R
Robert Clark
So maybe a better option then is to only get an inverter and a battery to battery charger?
We don't spend long in one place so will have plenty of opportunity to charge the batteries as we're going along,
Really wanted the option to stay places where there is no electric and still enjoy a few little luxuries
R
Robert Clark
Hi Pappajohn
Excuse my ignorance but is that 45% reserve taking into account 2 batteries, or just 1?
The BIG question, would we be able to run the coffee machine for 5 mins, the toaster for 5 mins, the towel rail for 2 hours and the hair dryer for 10 mins off the two batteries?
Have you got a pic of your towel dryer please?
Regards
Robert
Apr 13, 2012
5,544
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Make coffee and toast then dry the hair + charge batteries = generator
(y)
Scout
3,959
121,258
South Yorkshire
chic c line
for those of us the dont speak german, whats that then? looks like an inverter, but its got mains input? so is it a inverter/charger? just guessing there! whats it do
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Where would you go for a like for like quote?
Top class branded equipment fitted by one of the best installers in the country with an after-sales reputation second to none. There are probably only one or two other suppliers who you could genuinely compare quotes with.
On the other hand, it's very high spec kit & some might say it's overkill for the requirement. Those top spec inverter/chargers are the ultimate in convenience but only really come into their own when your demand for 230v power can exceed the ability of the EHU to provide it. If you spend a lot of time on sites that only provide a 5A supply, then they are very useful, but a normal UK 16A supply would be fine without it. They were originally developed for marine use - apparently marina shore power supplies are not often to the campsite standards we are used to.
Is your existing charger any good? Does it need replacing? As a Battery Master is included, we can assume that your existing 12v control system isn't anything special & doesn't already keep your vehicle battery topped up.
If you want it (as opposed to need it) & can afford it, I would say go for it. You can always buy cheaper, but then would you sleep as well, wondering if it was all going to work? Personally, I would have to compromise on the inverter/charger, but that's because I'm broke!
R
Robert Clark
To be honest, I'm now skeptical about the benefit / efficiency of the solar panel and also how much power the inverter would provide from 2 x 115ah leisure batteries, if we had no EHU. I appreciate your comment regarding supporting an EHU, but we're careful with our energy consumption and plan our usage not to exceed the resources available at any site we've be on so far. I don't believe that we could live 'off grid' for two or three days on the power we'd get from two leisure batteries, with 1 solar panel, so in that respect its a lot of money to spend simply to act as a back up for a EHU.
Maybe we need to choose sites with hook ups when we can, and live without our 'luxuries' when we're off-grid. I like the thought though of using a slow cooker to cook our food when we're on the move, but a 12v slow cooker, or cigarette lighter inverter would provide this - maybe an inexpensive fallback plan?
Regards
Robert
Techno
Jul 28, 2010
15,475
20,756
May 2010
To be effective with solar you need plenty and plenty of battery capacity to store it. AND A BIG PAYLOAD
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes it's a UPS 2000watt continuous pure sine inverter with 15 amp three stage charger. I won't need the charger except on rare occassions but I got mine on ebay auction for £216 :sneaky:
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Now you know the price of the ultimate solution, having a fresh look at your requirements makes sense. If you are only going to spend the occasional night away from EHU, then would it be possible to forego the hairdrier with a bit of planning? Easy for me to ask - I'm not in the line of fire! :D
Coffee machine is more difficult, but there are other ways of making good coffee, just as there are other ways of making toast.
With the proposed 100W solar panel & 2 x 115Ah batteries, I don't think I would be comfortable with the inverter using much above 600W when relying on batteries alone. I can't back that up with facts & figures I'm afraid - it's more a gut feeling & there are others on here with more genuine knowledge about what batteries are capable of. I'm sure others are comfortable with 1000W+, so long as it's only ever for a few minutes at a time.
The combo unit specified is at it's best when combining a restricted EHU with your batteries to give you 2000W when you need it & then automatically keep the batteries recharged when you don't. If you are on a 1200W EHU (approx 5A), they are ideal.
As Techno100 says, more battery storage capacity is always good, so long as you have both the physical space & the spare payload available.
One other point - if your batteries are genuine leisure batteries, are they rated for the sort of discharge current a 2000W invertor will pull? See pappajohn's first post.
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
2x115 batteries Max discharge 50% or their knackered so you have 115ah max more like 100 so will not take long to use the lot.
My suggestion would be b2b plus 200w solar about £500 + fitting (sorry eddi)
D
Deleted member 29692
I can vouch for the solar panels. The last time we were out it was 4 days/nights with no hookup at a music festival and even with overcast weather didn't notice the batteries dip below full. We have 200W of solar (fitted by Vanbitz) looking after 2 x 110ah batteries and a battery master.
This is true. Do you really need to take half your kitchen from home with you? Boil water in the kettle and use a caffetiere will make far better coffee than any of those instant machine things any day.
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
oh to be at the mercy of the leisure industry. And pump lpg is so cheap now aswell...59pltr. We have a 250w home type panel, 12v controller, and 2000w inverter, running 2x110amp batteries, £500 the lot, and we hardly ever have hook up, summer or winter.
19,346
30,235
Hi Pappajohn
Regards
Robert
Hi Robert
We have the Nespresso machine running off two 80ah GEL batteries using 2kw inverter, if I watch the battery voltage while using the coffee machine it only draws maximum amps for a short period while it warms up, we also use a microwave for hot milk (4 minutes) and wife uses hair dryer, no problems as long as we get some sun and the 360 watts of solar charge it all back up in an hour or two ready for the next coffee or uncle bens rice.
You will need a pure sine wave inverter for the Nespresso machine to run.
Cal54
3,806
62,014
Southport, UK
Leisuredrive Renoir
Since 1996
Heated towel rail, what a luxury! I use a good quality face cloth after showering and then a towel, it's amazing how successful this arrangement is - no soggy towels. Face clothes can easily be rinsed through and having 2/3 available is ideal.
May 23, 2013
1,782
2,816
Not on the Coast East Sussex
Hymer B504
Hi Robert
What inverter do you have ?
MikeD
3,936
3,697
London
IH PVC
With your Funster discount - you can have a week away (y)(y)
But 1st class work with a 1st class warranty does cost.
I suspect you will have years of service out of the equipment and it will never give you any problems. :):)
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
what doesn't your present system do that you need to spend all that money, in our van we have an 110 battery and an 80 , I know you are not supposed to mix them but the 80 came free so stuck it in,but we used to manage with just the big one and we have never run out of battery,no solar no nowt and we are just now onour second European tour on Aires and fp
