Removing Satellite System (1 Viewer)
enjohn49
28
9
Northamptonshire
Coach Built
Since 1990
Hi, can anyone help me with the removal of a Oyster Vision satellite system please? I am about to change my motorhome and am going to remove the system myself. I have removed previous systems before, however I am not sure of how to remove the control panel as it is different to the last one I removed. The system is about 3 years old and has the small control panel with 3 buttons at the bottom. I think it may just be stuck on, but I don't want to attack it and then find that it was screwed on! I suspect it would all end in tears!!:cry: Any guidance on this would really be appreciated. Thank you
eddie
8,169
41,337
Taunton Somerset
RV
since 1989
There are (should be) removeable panels either end that clip on. There will be screws behind the two panels. There is also a slot for an SD card should the system ever need updating
Thats the easy bit.
Removing the roof panel cable and gland will make you sweat. No tricks just a chees wire, blades and a selection of scrapers to do the job
Good luck ;) post if you need more help
eddie
8,169
41,337
Taunton Somerset
RV
since 1989
enjohn49
enjohn49
28
9
Northamptonshire
Coach Built
Since 1990
Thanks once again. The other alternative I had considered, was leaving the cable then renewing when refitting the system. I have also sent a request for a quote.
eddie
8,169
41,337
Taunton Somerset
RV
since 1989
That will be expensive. We tend to leave the plate as it is more cost effective for our customers to buy a new one than pay us by the hour to remove it. if you have plenty of time that is a different matter.
enjohn49
enjohn49
28
9
Northamptonshire
Coach Built
Since 1990
I will remove the old system myself but would need to have it refitted professionally. I have just looked at the control panel and it appears that the installer decided to stick the unit (with self adhesive pad?) instead of fitting it into a housing!
