rb panel van conversion begins ! (1 Viewer)
just wandering
46
45
Paisley
I'm a newbie
We have given the insulation of our van allot of thought as its one of the most important parts of the conversion.
Its nearly as important as choosing the right size fridge to fit the beers in :LOL::LOL:
I have been reading up on all the different types available and have also seen what the main manufacturers use.
We have taken on all the valuable comments from the forum and finally decided on....
I intend to stick this straight on to the vans interior shell. This will form my first layer of insulation and vapor barrier.
This is the sort of thing the big manufacturers use such as IH and Globecar but a little thicker at 10 mm.
On top of this i will be applying a second layer of Kingspan / Celotex type material. This will be a minimum of 25 mm and in some areas around 50mm. This will be stuck using a high temperature adhesive. Some areas of the van are very hard to insulate using the above products so i will be using sheep's wool and gun applied expanding foam (y)
Hi Ralph-n-Bev.
This is also an area i've spent so much time on, researching, researching and even more researching. I finaly came across Happily Homeless on youtube and was interested in the materials he was using, but a bit pricey for me. (see video)
Then I came across RattleMatt on fleabay: http://www.ebay.co.uk/itm/300719999472?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
I figure I'd need 3 of these, 300 sqft/28 sqm - plus the bubble foil.
Then I found this post with the link to harrisons trim supplies. I've had a look and I think this might be what i'm looking for. It seems to combine sound deadner and foil insulation into 1 material. Would that be correct?
How did you find it working with this material, was it easy enough to apply?
Cheers,
Jack
Sep 16, 2013
2,220
7,993
Horncastle, UK
@just wandering Just a quick note on insulation - it really depends on what your going to use your van for.
I've never used the bubble wrap stuff but from doing literally a ton of research before I insulated my own van it seamed the most effective ways were using Kingspan (or similar) or even better, having it spray foamed inside.
I went with Kingspan. Insulation was really important for me as my dog likes to be in the van as often as possible. My van can be out in baking hot direct sun all day long and still be cool in the back when I open the door. It's also really easy to heat in the dead of winter.
I would suggest also joining the SBMCC which is a self-build forum. Lots of great info from some very good builders.
11,954
9,158
Hi JW I also use both the bubble wrap stuff and Kingspan along with spray foam for the insulation --simply spray/glue/contact adhesive to van and BW then stick it on -you can do the same with the KS and fill in any gaps with the spray foam -You can also buy spray foam kits and do the whole van with that -I currently keep getting pop ups for it at £199 pl,us vat -it should give you enough for a whole van -not sure if insulation is as good as BW plus KS though
terry
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
@just wandering Insulation.....What a minefield.
The foil back adhesive foam on a roll was great to work with (y) Very sticky and easy to cut to shape.
I went over mine with a heat gun which helped dress it into the ribs of the bodywork.
I know this is just what some of the main converter's use and class it as fully winterized :eek:
It creates a great base layer but personally would go for Kingspan or similar on top of it.
I managed 50mm Kingspan in most of the side walls and 25mm ceiling and floor.
We have only been out in the Pug in the summer months and have to say we are pleased with the internal temperatures :D
Take your time deciding over this, but build in as much as you can without compromising internal space (y)
Don Quixote
2,966
5,259
Lost in La Mancha, Spain
VW T6 Campervan
Ralph n Bev, what a great read and I'm full of respect for you and your work. I hope the MH brings you many hours of fun after all the hard work. A FIRST CLASS job Sir.
Jan 28, 2008
10,134
18,418
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Hi Ralph-n-Bev.
Cheers,
Jack
have you checked the weight of the rattle mat some sound deadening matierials are extremely heavy
Dec 4, 2014
1,373
4,151
Cheshire
Been around the block a few times😉
Said it before & I'll say it again.
A fabulous job from start to finish well thought out & well executed.
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
Ordered and received my final sheet of Furniture board last week :(
Saturday i had a a day on the workbench cutting and routing the last five doors and making two table tops :)
The furniture is almost complete, I just have a couple of doors to hang under the sink unit. They will be finished once the hot water and gas connections have been made underneath. Hoping the hot water heater is ready mid August, i need this to finish the plumbing, they keep moving the launch date on this new boiler www.propexheatsource.co.uk/heaters/expanse
Now when you open the main sliding door it looks finished (y)
Just the cab seat bases to box in, and a carpet down then Pug will be finished internally. Externally i still have water and a gas tank to fit.
I had a good chunk of furniture board left so decided to make a couple different size table tops.
One we can use for drinks when lounging. The bigger one is cut to fit nicely into the wardrobe ( hence the coffin shape ! )
As we are on catch up for lost getaway weekends, we are heading up to the Yorkshire dales next weekend for some walking good food and real ale (y)
The following weekend we are heading down to Saltfleet with the Funsters :)
Anyone wanting to have a nosey is more than welcome. Just look out for the... PUG... registration
Catch up soon.....Ralph
lesr48
98
85
Ilkeston, Derbyshire
Rimor Katamarano
Since 2014
What an absolutely FANTASTIC job you have done - Congratulations. I look forward to having a neb at Saltfleet.
Puddleduck
12,387
44,092
Scottish Borders
Without at present
On and off for many years.
Looks fabulous. Hope you enjoy every minute.
One thing with building your own is that you know where every screw and pipe is.
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
Thanks puddleduck
Yes, that's one of the main reasons I've built one. That and being able to choose the Quality fixtures and fittings as well. I've never been happy with 12v electrics in motorhomes and caravans . So wanted to put my own chosen system in , as I know it works . And will keep on working . I also wanted good quality solid furniture board , as I've found even quality converters don't use it . Being too expensive.
Even down to the hinges I've chosen , strong and solid but soft closing. Everything is built to last. We plan on Pug lasting us indefinatley . It's not been a cheap project , we could have bought a new Motorhome for what we've spent . But we know we will have a solid conversion, built to our own spec.
Ralph
UK Pete
284
333
kent
Renault van conversion
on/off since 1991in campervanss
Ralph you are a true craftsman, your workmanship is superb, well done on all your hard work and its looking near on finished , whats left to do other than enjoy
pete
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
Haha.
And we will enjoy. We've got so many plans. Let's just hope health and circumstances permit. Thanks Pete.
I've surprised my self , being a Brickie I've never done any carpentry before. I'm not a craftsman :notworthy2:, Wood wise.
Brick wise yes!
I've just taken my time and wanted it done right. I keep going into Pug and thinking , " I've done this" :Eeek::rofl:
885
929
Norfolk.
Autotrail cheyenne
2008-20??
We briefly met at the "Soul "do at Newark and you let me look at you then unfinished Pug,I have to say even then I was more than impressed.But now from the pictures on here, he is fantastic.I hope to see you again some time but in the meantime ENJOY the Pug after all your hard work........Martin(y)
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
Thanks Martin. We've still got all the underslung tanks and webasto to put on yet. But Pug is nearly there. I don't know what I'll do with my self, with all the spare time.
No doubt Bev will have us booked for lots of weekends away.
Can't wait.
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
[This is where we will be keeping all the tea and coffee cups and plates etc.
I have had a couple of Fiamma Omni-Stop gadgets sat in the shed for a couple of years.
I knew one day they would come in handy ;)
The bracket holds the bowls and plates in place tightly and un-clips easily by pushing down with you thumb and lifting the retaining clip (y)] end quote
I have been watching your build and I am severely impressed and jealous of your skills at the same time, but if I could offer one bit of advice it would be about the Fiamma stops.
Whenever you park up anywhere, especially for long periods, always lift the stops away from the plates etc to release the tension.
We have one and I hadn't realised that over time, with temperature changes etc, the plastic arm loses it's springiness and allows everything to move and rattle.
It just doesn't hold everything in place properly anymore.
I would hate a small thing like that to spoil your enjoyment and hard work.
I hope you don't mind me mentioning it. :notworthy2:
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
@knokinonabit
Thanks for your kind comments and the advice on the fiamma stop. We shall only press it down whilst on the move then release it when static, now. As we had it pressed down permenantly until wanting a plate or bowl before.
RnB
sedge
Jul 7, 2009
5,511
13,156
Nr Jct 3 M6
Aug 09 to date 9,000 miles!
I'm a bit concerned about the crockery in Bev's cupboard, YES she can offer me a dinner and/or a pudding.
But - does she really expect me to eat a slice of her lovely cake that she's going to offer me, without a tea plate?
Looks like Pete will have to go without anyway ........
:whistle2:
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
:whistle2:
I've only put what correlle provide for two . If you want to eat cake with us, you'll have to bring your own tea plate ! :laughing:
Keeping the weights down , for my prosecco!
madgeD
259
480
Cleveland
Van conversion
since 2005
What a beautiful van what a lucky lady Bev is , but I'm sure she knows it. I've enjoyed looking at your progress and will look forward to seeing Bevs video when she does it.
I hope you have many happy years in this lovely van.
Ralph-n-Bev
Nov 30, 2009
6,548
149,352
Pickering
PVC the PUG
Thanks MadgeD.
Yes I'm very lucky. Ralph's a great husband and dad, he's always worked very hard for all his family.
And to top it all he's built us a fab PVC , in Pug ! We are looking forward to lots of adventures in him.
I don't tell Ralph how much he is appreciated. Often enough.
But he is , lots and lots. :inlove:
