How much??? Motorhome MPG (1 Viewer)
hdvrod
859
733
devon
since jan 2011
Think its all down to how you drive and the type of roads you are on,I have 2.9, 5 cyl turbo sprinter circa 1997,average between 25-27.
54mud
100
55
Stone, Staffordshire
Coach Built
24 on and off
My Land Rover Defender based MH, with over cab bed and running near it's 3.5 ton limit does on average 28mpg. Thats with a 300TDI, big intercooler and no electronics and my right foot is the cruise control. And the speedo is not to far off what the satnav reads.:thumb:
Oct 28, 2013
490
443
Lincoln
That's pretty good going for a 300TDi.
Mine only used to get 27mpg in standard form...
golly
2,006
69,795
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
What size engine is in your Merc ? our Auto-Sleeper Sprinter based Merc is 2.1 TDCi Automatic and we average 25.6mpg. Worst we got was 21.65 mpg and the best 30.26 mpg but I do drive like a nun and use the cruise control whenever its safe to do so.
John
Feb 24, 2013
13,109
101,579
Bolsover, Derbyshire
Hymer S800
not long enough
I reckon a genuine 30mpg is as likely as gassing!! :ROFLMAO:
I get virtually the same mpg as OP, we have a Mercedes Sprinter based auto 3.0, the actual cc is near this, but V5 says 3000cc (6 cylinder I think, sorry not at all techy) we are 5 ton max though with 6 wheels
It doesn't make a deal of difference how fast we go, but I never go over 65, usually 60 on motorways, don't bother with cruise control, not convinced it helps with mpg. we have been down at 18 and over 24 on a typical 200 + mile run. Computer and actual refills seem to match quite well
But a point made by DevonBeeKeeper, made we wonder about mine, when I manoeuvre at home before leaving, having been stood, it sometimes feels like my brakes are slightly on, like handbrake only half released, being an auto I only use Park don't use handbrake, although I do pull it on and off each time out to make sure cable stays free for MOT. When I am underway I am not aware of similar restrictions, including pulling away from lights etc. no performance issue at all there, but could slightly binding brakes cause enough drag to affect mpg? There is no noise or smell from brakes at all. Anybody else get this, I might run a new thread
54mud
100
55
Coach Built
24 on and off
Before it was converted and was a standard hard top body, the best I got was 35mpg when touring France in 2001. It is well maintained with the big Allysport intercooler and Hiclones fitted, and steady driving.
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
Hi, I have a 2.8jtd 2004 Ducato remapped. I drive quiet hard, had the gvw upped to 4000kg as I was always over 3500kg and get around 23/25 mpg
Steve
Volusia
205
173
Haute Vienne France
Recent converts from boating
It's a hobby and pastime, the fact you won't get consumption at the level of the family car or van come to that, shouldn't really be a great consideration. After all we do carry everything, and in our case, that does include the kitchen sink! ;0)
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Having read the OP my faith has been restored in old school Mercedes technology. My 24 year old 2.9 turbo 5 pot running at 4.6 ton towing a trailer with a Smart car on does 19/22 MPG on Bio and 20/24 on fossil diesel. I dont nurse it otherwise it would stop. Once wound up to 56/60 MPH it sits there happily until a slight incline comes into sight. Then you have to floor it. By the sounds of things Mercedes have not moved on that much in the last 20 years. It is serviced at the correct intervals and oil changes at 5000 miles, regardless of where I am at the time. Tyre pressures do make a difference and I run 70 PSI front and 75 PSI on the twin rears.
Oct 28, 2013
490
443
Lincoln
Mine had the big intercooler and regular servicing too but, thinking about it, it may have had something to do with it being an automatic.
I've never owned the manual version to compare, is yours manual?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Time I cheered you lot up
6800cc V10 Petrol 12-14 max:thumb:
And I dont care:thumb:
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
My MoHo, Autotrail Apache 700SE / Fiat 2.8 does 31 average to the gallon (several times tank full to tank full) that's driven at max 58mph, I am meticulous about tyre pressures and have found on Michelin Agilas 16inch run at 75psi which gives us the best mpg and comfort.
I will say that the mpg drops substantially once up around the 70mph mark.
My last MoHo was 3 mpg better overnight when I found the tracking was toeing out quite a bit - has to be one of the worst mpg 'affecters' and will cost a fortune in tyres too.
Regards,
Trikeman. :winky:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
You sure as hell would care if you did the mileages I do :ROFLMAO:
oldmanriver
183
179
gillingham kent
autotrail comanche
im a newbie
swift kontiki 669 3.0 litre about 22 mpg but don't drop below 65mph often touch 70 mph if I run at 55-60 mph it does make a difference but I didn't buy it for the economy, my comfort comes first
Oct 28, 2013
490
443
Lincoln
Yep,, and a gallon of two stroke!
Much the same as. My kwaka. H1
But in those days who cared about mpg!
:thumb::ROFLMAO:
My old man did.....you should have heard him whinging and moaning about the cost of fuel rising to 75p / GALLON!!!
Mind you, he was only bringing home £13 / week....
Chris
21,057
279,492
10 years
I never really check it to be honest.
My new van seems to be more economical than my 2008 van , but as a family we use a lot less fuel than we used to 3-4 years ago. Economical cars, using local campsites and even walking to the shops:)Eeek:)
I begrudge the Government the tax.
LARRY99
298
444
South wales
C class Rv/ Dethleff
Ages
Have you still got it? 500 or 750
I wish, long since gone , they are going for a small fortune now!
H1 500
H2 750
Both mean machines in their day ( and Kawasaki only made bikes as a sideline, )
£ 595 brand new, and it could have bought a bonnie cheaper! But why follow the pack
Still have my wing, old mans bike, but hey I am a old man!
May 6, 2010
547
638
Doncaster
April 2010
Reading these posts I'm more than happy with what my 8100cc V8 Vortec is getting sucking on LPG :Smile:
I too had a 350 LC, a guy round the corner had 500 LC in Malboro colours :Smile: although I always wanted the RG500 before moving onto bigger 4 strokes :thumb:
Hercules
44
48
SWANSEA
since 2005
I would have loved to have had an RG500, but family commitments came along, I later had serious big 4 strokes, but you can't beat the feeling of riding a fast stroker.
