Holding Water hose simple solution (1 Viewer)
Dec 17, 2019
1,031
1,819
St Leonards, Dorset, UK
Carthago Malibu
Converted caravanner!
Bought one of those Rheinland gizmos that allows direction connection with a Hozelok fitting. But I’m not convinced that it want damage the tank through over pressurisation. The water does come out when it fills up but a lot of water then shoots back out of the filler cap when you disconnect, which to me suggests it’s inflating the tank.
Anyway I found a really simple solution with a good old elastic band…….
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Mine's terrible for it. I have to turn the tap on slowly or it blows the hose out of the hole.
Every action has an equal and opposite reaction... Always remember that. You heard it here first 😎😝
32,673
66,645
I agree ref the pressure build up for MHs/campers which don't have a proper overflow but instead rely on the excess water coming out through a small hole in the filler rim, they simply do not work 'safely' IMV. We had an issue with a vented Heosafe connector which didn't allow any blow-back via the filler 'hole' and not enough via the overflow hole so instead meant that once the tank was full the excess water was pushed out and through one of the top inspection caps and caused flooding to the inside of the camper, after that we never attempted to use it again.
My solution involved a coat hanger 'hook' and worked very well indeed with our PVCs and now with our A-class:
32,673
66,645
Personally I just stick the hose in the hole with no fittings..
Me to, 3 Motorhomes 13 years never had a hose fall out.
Whilst you can do that on many MHs on some PVC conversions the pipe has a sharp bend in it just behind the filler so it's impossible to push the hose in sufficiently for it to stay put.
53,493
150,285
You are not poking it in the hole far enough, a man of your age should know that.
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
I just shove it in deeper. It seems to work 😂🤭🤭.
Coolcats
5,946
9,953
HymerCar Ayres Rock
Doesn’t happen on our PVC, just stick the hose in and let it fill up., but then again it is a Hymer 😉
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
They have water tanks now.......WoW
32,673
66,645
Where's the water tank?
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Been to my magic shed and made something 😇
Peice of ½" A/C pipe with a couple of bends on it with a ring of ⅞ pipe crimped round it and brazed on. Locks in great 👌
15mm plumbing pipe might be better for most hoses but my pipe is small 🥺🥸
32,673
66,645
Made up for by the very large 'sticky-in' bit though! :LOL:
Coolcats
5,946
9,953
HymerCar Ayres Rock
It’s on the offside rear and holds 100 litres as does the grey waste. I just put the hose in and do other things until it’s full.
Jul 24, 2015
374
947
Ramsgate Kent
Fiat ducato c class
5 years
I was in France once and rammed my hose in to deep and the end fell off!
35 degree heat and I was sweating
Tombola
4,839
15,733
Merseyside
Rapido 8094DF
I see someone used to watch take art with tony heart as a kid :) :roflmto:
bang on
James-Alex
567
1,905
Bath. Somerset
Autotrail excel 640G
How does that attach to me “watering can” 😂
32,673
66,645
What type of hose do you use?
Jul 31, 2019
872
8,208
Devon
Swift Bessecar 584
Since April 2019
Ha.... I always get wet when filling up🚿🚿🚿
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
I fitted a genuine Bullfinch hozelock connector and ran it to a toilet style fill valve so it turns itself off when full. I just plug it in and go back later to remove it. No need to pay any attention. (I can also bypass the valve to get an extra 20 litres in).
32,673
66,645
It’s a blue food grade one with a ‘hozelock’ style end on it just place it into the inlet turn the water on and leave it.
Ah, I thought you meant you were able to push the 'naked' hose into the filler and down into the inner pipe, that's where the kink is that prevents this on many rear bed PVCs where the water tank is on the side rather than on the floor or underneath - have you tried putting a 'naked' hose in? :unsure:
bobandjanie
8,165
15,812
Javea, Spain
Pilote V600g
We use one of these, when it's full the water comes out the overflow, but I normally hear the air before that happens and turn it off. 😎 Bob.
Coolcats
5,946
9,953
HymerCar Ayres Rock
The tank is in the same position as you describe but the way Hymer have plumbed it in there is no kink to date we have not used a ‘naked’ pipe. I can see how that would work though.
ctc
Oct 12, 2015
1,518
2,551
Crowle
Hymer b680
New
I don't Understand, you actually do this job yourself?
