fridge wont stay on (1 Viewer)
sean n maggie
672
327
leeds
autotrail
having a problem with the fridge , it was working ok on the gas when we got to france, but wont work now, it wont ignite and stay on , it works on 12v when traveling and on electric on hook up,,i have tried to ignite with a flame but wont have it,,,,,any ideas please ?
11,956
16,570
If it lights, then goes out when you release the knob, it's likely that the jet is partially blocked. If it doesn't light at all the jet is probably totally blocked. If you can reach the jet assembly to light it then changing the jet will be a fairly quick job. They're so fine that it's rarely worth cleaning them (with some it's impossible) so a new jet is the easiest fix.
sean n maggie
sean n maggie
672
327
leeds
autotrail
thanks for that,,,,not got one with me and as in france at the moment , now looking for aires with electric hook up.....
Dec 12, 2010
5,415
21,602
Cumbria
What model fridge is it ? If you tried lighting it with a flame, I’d imagine the fault may be the gas supply solenoid ( if fitted ) the lucar connector to ours had corroded and came off and although the igniter was sparking merrily away, the gas wasn’t getting to the burner.
tambo
874
639
Dunfermline fife scotland
a class
Ah just an idea but we had this very same problem last week fridge had been working fine on gas and one night it wouldn't light on gas.
I took the lower vent of outside and removed the aluminium cowl around the burner and you wouldn't believe it but there was the burnt remains of a bee or some other insect on top of the burner.
Gave it a good blow out and retried the fridge .....worked fine again since
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Is there gas in it?
Biged
159
70
Nottingham
No longer looking
newbie
Unlikely to be a blocked jet more likely a defective thermocouple, a really cheap fix on a gas fire, don't know about a fridge.
Wickolad
490
542
Wickersley
Check that the thermocouple is siting squarely in the pilot light flame, it may have moved.
Also check that the 12v supply is there, you don't mention if it fires up at all or just doesn't stay in. If it doesn't fire up at all there could be a 12v supply problem ie loose connection or fuse.
I believe running with the engine is fed differently... Via the cab battery and alternator (I may be wrong) not 100% ofay with systems myself yet.
10,121
18,387
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
9 times out of 10 it will be a blocked jet you can get to it through the lower vent three screws one nut and your there remember to test for gas leaks on the nut after you put it back together
Wickolad
490
542
Wickersley
Another really daft question, did you isolate gas supply for travelling?
Not that I've ever forgotten to put it back on.....
sean n maggie
sean n maggie
672
327
leeds
autotrail
thanks for all the replies,,the fridge wont even light ,,i have taken the cover off and tried to light it manually with a match,,its like there is no gas there,,it was working ok and one day we set off with it still lit,,and its never worked since...so guess it might have something to do with that too...:(
