Frankieboy1?
- Mar 21, 2021
- 5
- 0
- CORADO T138
fridge not working on 240v
Perhaps a bit more detail would help.fridge not working on 240v
Hi and welcome, is that a statement or a question?fridge not working on 240v
Ah a question. Check you have leccy to it first then and next how many volts.working on both 12v and gas, but not on 240v. The fault when you look in the book says 20% less power than required operating voltage
Maybe that fault message flashes whenever the voltage is '20% or more' less than the required operating voltage. So if the voltage was zero, you might get the same message. So could be the 240V element fuse/MCB or a bad connection.the only flashing lights are the fault light and a number (8) and spanner, which when you look up the fault it says 20% less power than required operating voltage.
Yes my laptop flashes it's 'low battery' LED it's not actually low... It's disconnectedMaybe that fault message flashes whenever the voltage is '20% or more' less than the required operating voltage. So if the voltage was zero, you might get the same message. So could be the 240V element fuse/MCB or a bad connection.
