fridge not working on 240v (1 Viewer)
F
Frankieboy1?
5
CORADO T138
working on both 12v and gas, but not on 240v. The fault when you look in the book says 20% less power than required operating voltage
Badknee
7,408
412,941
notloB
Vantage Neo
Living the dream.
Ah a question. Check you have leccy to it first then and next how many volts.
F
Frankieboy1?
5
CORADO T138
Hi, there is power going to the MH, the lights all work and I have a small electric heater in there for when it gets very cold, this is working fine.
Nov 4, 2011
5,943
39,022
Uk
Check YouTube
Jan 2, 2015
2,472
8,630
Cumbria
Burstner Solano t725
since 2014
This would tend to suggest that the power supply to the fridge is less than 240v.
Are you in the UK or on the Continent?
We have experienced this a couple of times when in Spain when the Site power supply was a "little erratic":rolleyes: and not supplying the full 230/240 volts.
If you are able, try an alternative supply point?
Good Luck
F
Frankieboy1?
5
CORADO T138
Hi all. I am in the UK, the only flashing lights are the fault light and a number (8) and spanner, which when you look up the fault it says 20% less power than required operating voltage. It is just not working on 240v.
Apr 27, 2016
6,873
7,995
Manchester
A class Hymer
Since the 80s
Maybe that fault message flashes whenever the voltage is '20% or more' less than the required operating voltage. So if the voltage was zero, you might get the same message. So could be the 240V element fuse/MCB or a bad connection.
Jan 19, 2014
9,395
24,785
Derbyshire
Elddis Accordo 105
since 2014
Yes my laptop flashes it's 'low battery' LED it's not actually low... It's disconnected šŸ˜†
