External BBQ use with gas bottle (1 Viewer)
Stonemags76
1,284
4,003
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
Couldn’t think how to phrase this better! We have an external gas point for a BBQ, and an underslung gas tank. I was wondering if we could convert the BBQ point to take a local gas bottle in case we can’t get lpg? I know lpg is available most places, but we can get through a fair bit if it’s cold, and I’m worried about running out! Is it a daft question??
2,444
10,667
not daft, its what many people do when visiting countries where Autogas isn't available.. what we did in Morocco
gas bottle with a regulator and feed into gas system..
waiting for the nay sayers..
wasp
1,724
18,180
Warsop
None gone caravannin
I’ve done that,but, the problem arises if the connection is not very good. The C&CC frown on it but if you are discreet .(y)(y)
Stonemags76
Stonemags76
1,284
4,003
Derbyshire Dales
So the gas bottle fitted with a regulator can connect into the external bbq point?
43,398
49,992
Yes, even the refillable bottle installers at shows do it where lpg isn't available to fill the new bottles.
They simply use one of the customers Calor bottles connected to the BBQ point.
19,474
30,858
Connected to the filler point I would have thought, with the pipe as suggested above.
43,398
49,992
Sorry, that would mean filling the new bottle with gas vapour and going through the onboard regulator as well as the bottle regulator.
43,398
49,992
43,398
49,992
In any case, the OPs question was can they use the BBQ point to feed the gas system.
Of course it can be done in any number of ways but that wasn't the question.
Badknee
7,414
414,833
notloB
Vantage Neo
Living the dream.
Yes, your bbq point is after the regulator so the bottle your using would need one fitted. Your bbw point is open to the rest of the Moho system after the fitted regulator that's why you need another one. (y)
Basildog
2,213
3,602
No bottle regulator needed
tonka
10,856
21,585
Cannock, Staffs
A class Burstner 800
Since 2000
Visit any Spanish campsite and you will see lots of bottles connected in that way...
one point that was raised on a past discussion.. You have a fire, the inspection of the remains shows you had a bottle connected like that. Will your insurance pay out ??? Worst case I know but something to think about.
A "Jumbo adaptor" is just a valve and not a regulator.
I use one of these on my Autotrail and feed in via the built in regulator, used it for years.
True that if you use a Spanish regulator on the bottle and then try and go via the onboard regulator it does give problems and it lowers the pressure a lot.
11,857
14,104
The connector to the filler point does not have a regulator, it's just the van regulator that's used. You must have at least one completely empty bottle for it to work though.
wasp
1,724
18,180
Warsop
Yes but you need the hose adapter for it and there are two so you will have to know what year your van is to get the right one. E Bay is your friend (y)(y)(y) All i did was connect the BBQ point turn on gas bottle and turn the onboard one off
19,474
30,858
No regulator on the bottle feeding the system so you are putting gas at higher pressure into the system you have fitted, doing it the other way every van would have to have a BBQ point before it could have refillables.
19,474
30,858
Been right through that page and nothing listed for that purpose.
To use the filler point you would need something similar to an LPG pump fill nozzle to fit your filler point... Not feasible.
Page 6, it's called local cylinder connection hose.
11,960
16,579
BBQ point connection is simple, cheap, and safe if the bottle is on a sensible length of hose and can't fall over. If you carry a couple of BBQ connectors you can make up hoses with the appropriate regulator to fit more than one make of bottle if, for example, you are travelling abroad. The van system and BBQ point need no modification.
2,444
10,667
oh dear.. and it was such a simple question
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Would of thought as a lot of places have different bottle fittings best option is a hose fitting for bbq point with hose and then purchase regulator to fit bottle for whatever country you are in.
Thats what i would do
11,960
16,579
As I suggested in post 21 :D
2,444
10,667
as I suggested in post #2 ;)
