E-Bikes and Toad (1 Viewer)
Jun 18, 2008
1,588
2,281
Lancaster
Since June 2008
So, having finally had a towbar fitted to the motorhome, and the little C1 is booked in to get an A-frame fitted, the problem has now arisen of what to do with the e-bikes.
My initial thought was to fit roof bars to the car but all options I’ve looked at say the bars aren’t suitable for e-bikes, presumably because of the weight? The smaller bike is 15kg without battery, the larger 18kg.
How do others manage?
Jan 26, 2017
3,488
11,797
Mid Suffolk.
Autosleeper Inca
Eight Years and 28,000 Miles.
May 5, 2014
246
635
Since 2011
If we decide to tow the Aygo then I don’t take the electric bikes. We alternatively use fold up brompton bikes which can be easily transported in the Aygo. It is possible to use the A Frame with the eBikes on the rear bike rack, but it‘s more of a faff to unhook both car and bikes.
sparky
97
85
bingley yorkshire
a class burstner aviano i
30 years
Hi I tow an ayago a want take my electric bike as well so I bought a maxxrac tow bar mounted and hope to hang the bike on that between the tow car the fixings for the maxxrac bolt on behind the tow ball permantley but the rac can be removed easily when not needed have not tried it yet due to lock down but should work
Nasher
2,094
7,179
Pontardawe
Pug Boxer
Another vote for MaxxRaxx (providing it fits in between)
eddie
8,169
41,332
Taunton Somerset
RV
since 1989
We have a tow bard on the Toad, and a ebike carrier that is tow ball mounted
Sep 29, 2019
3,065
7,085
Hymer Exsis
20 years
Just be careful of tight bends. You might need to check it on a car park before saying it will work for sure.
53,648
150,782
Most e-bikes weigh 20 to 25 kg, yours are no heaver that a lot of cheap standard push bikes so should be OK on a roof rack type.
Sep 29, 2019
3,065
7,085
Hymer Exsis
20 years
I have owned a lot of roof racks. Most specify a 70KG max load. So the two bikes should be fine. Thule are my recommended brand, never let me down.
Oct 7, 2019
173
474
Burstner td590 lyseo
campervan for 5 years, motorhome since May 19
I bought these-
They have the added advantage of reducing your wight further as you need to remove the front wheels.
Also, from a security point of view who wants to steal two unicycles?
I keep the front wheels in the motorhome separate from the bikes.
Graydo
Oct 27, 2013
712
11,168
Portglenone, Northern Ireland.
Elddis Magnum185GT
Since July 2012
All you have to do is lift a dead weight of 20kg plus from low down to above shoulder height, with arms out to the front. Can foresee muscle strain & slipped discs :oops: Hmmmm. :whatthe::unsure:. We took our Fiamma rack off the back of the van for that very reason & got a tow bar mounted one as so much lower.
Hplar
Roller Team T Line 7
I'm a newbie
43,367
49,719
Buy a towbar rack which fits between bar and ball....the A frame will only have a few kilos nose weight so will have very little affect on the overall weight.
If you have a Swan neck towbar you're stuffed though.
