Ducato Diesel Filter - water warning light (1 Viewer)
Apr 12, 2012
240
97
Fleet, UK
Pilote Atlantis 34
MoHoing since 09/04/12
The water-in-filter warning light is on on my dash.
Well, it starts off on (and doesn't go out after engine starts), but then after driving a bit it does go out, and then amusingly it flashes in antiphase with the indicators when they're going.
The engine is running lovely - fires up immediately and runs smoothly, and I've read on the internet that the water sensor can be a bit temperamental. So should I just ignore it as it's probably just being daft?
I've also read that the filter might have a drain plug on it, so I was thinking that it might be worth just draining off any water in case it is present? In which case, can anyone tell me how to do it?
I *think* I've found the filter - lurking behind the air filter bucket; grey cylinder, it does have what looks like a plastic wheel on the bottom of it... but didn't want to go unscrewing things without being sure.
It's a 1997 vintage, 2.5 TD.
Thanks for help and advice as ever ::bigsmile:
656
1,052
290
The universe
The "wheel" will either be the drain tap or the screw that holds the filter bowl on. Why not get a replacement filter and change it? They are only a few quid from your local parts dealer!
43,332
49,517
thats the water drain screw.
unscrew slowly untill water/fuel runs out.
ideally you need a cup/jamjar underneath to catch the waste fuel...half a cup should clear it of water.
