Driving off an leaving your gas on (by accident) (4 Viewers)
Paul J
220
40
I'm dumb, I'm only here as a reference point to make normal people feel clever. I do the kind of thing like leaving the gas on when I drive off site, in the case of a new Roller Team motorhome or similar equivalent, what would happen to my fridge (and anything else currently using the gas) when I attempt to drive off with said items still running ? I know that gas should be shut off at the valve before moving, but what it you forget ?
(I also like to drive off with the tv aerial extended at maximum height, I just do this stuff for the entertainment of others ;)
Paul
P.S : I believe the Roller Team fridge is somehow automatic, it can pick it's own energy source, but surely that means that it will switch to the EHU, or then back onto 12v when you drive away. that's my kind of feature :)
Paul J
Paul J
220
40
I'm going to love my new hobby, we're in the final stages of choosing, looking at Roller Team T-Line 590, and Chausson Welcome 530, both are kind of similar layouts, and I think made by the same group in the same factory, they both have pretty much everything we need, but are different in many ways, we'll be seeing if we can get a deal on one or the other during this week, then depending on what's in stock, I'll know wether we'll get it this summer or not.
Quite excited !
32,662
66,595
things have changed so much in the years I've been out of this hobby. I guess that everything on the new vans is electronically controlled. So I can leave the gas on, with the fridge running, drive away without changing a thing, and the fridge should shut off the gas supply, run on 12v. If I park up again, it will automatically re-light on gas ? then, upon arriving on site, the EHU will trigger it to go onto electric power ?
thats amazing !
... just remember to put it into auto mode when you are using it but more importantly to turn it off when you get back home and won't use it for a while otherwise you'll end up with no gas and, if it can also run on 12v when the engine's not running, flat batteries too!!!
7,513
19,945
Lanzarote
Nil by mouth
Lots
If it's really cold and decide to have a small bonfire in your camper, then it may be a good idea to turn off the gas.
Unless the missus wants a cuppa:)
Paul J
Paul J
220
40
Minxy Girl, "Automatic" isn't daft enough to flatten the battery is it ?
32,662
66,595
It will use whatever power source is available to it until it is depleted or gets too low so it might!
I haven't had an AES fridge for a long time but our old one could do it but the newer ones might have something to prevent this ... you'll need to check.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
No*.
But it could use up all your gas.
* unless it's been installed incorrectly, which I hope is unlikely. It's not possible to be 100% certain about such things because something might have been 'modified' by someone at sometime.
TerryL
6,188
8,190
North East
Low Profile
The official line is that you should turn your gas off when the vehicle is moving, unless you have the "Secumotion" anti-crash sensors.
I used to turn it off, but now only gets done getting on the Chunnel or ferry and when it's in storage.
Mr Chrysalis
2,367
318,019
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
We also have gas on all the time, crash sensors fitted and automatic changeover.
The satellite dish retracts when ignition is turned on, but I usually remember to lower it before setting off anyway
I’m quite scared of driving away with EHU connected, as I think that would do quite a lot of damage. The old van had an alarm that sounded if you turned in the ignition with the EHU connected. Now I rely on a checklist. ( I don’t know why I call her that; she’s from Glasgow, never been to Czechoslovakia)
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
The only problem is, if, your fridge is on gas, when you fuel up, there could be one almighty bang.
What will go "bang"?
Diesel won't.
Maybe a car next to you whose owner is spraying out petrol as he fuels up...
JJ :cool:
440
438
Somerset
since 2000
Always turn ours off when driving even though it can be left on as it changes automatically.I just prefer to have the gas totally isolated in case of any unforeseen problem.
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Remember parents unplugging the TV - and some unplugged (and probably still unplug) everything at night
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
My Gran would leave the flex of her vacuum cleaner on the floor for a while, to let the 'leccy in it escape before winding it up.
32,662
66,595
Yes & water off at the stopcock when going away as well as the electric off at the incoming mains switch. :LOL:
Its taken me years to stop mum from turning off her hard-driver recorder at home!
When I was little Mum always removed plugs from sockets before bed (we had a gas fridge) and if there was a thunder storm the aerial lead too!
scbunurse
84
52
Inverness
Test driving tomorrow !!!
if we turned the gas off the casserole wouldnt cook
Seriously - you can have the oven on while travelling!! Roast dinner on arrival sounds tempting! I have a Bailey Autograph 79 6 - I don't think the fridge switches automatically. I have to press the dial in and press the ignition until the needle moves round to the green bit......
Mr Chrysalis
2,367
318,019
Rapido 890F A Class
It’s safer than leaving a stew in a saucepan on the burner. Have to drive really slowly round corners and that tends to upset other road users
joka250
907
1,554
Fylde Coast.
Since 1985
Diesel won't.
JJ :cool:
Petrol vapour is heavier than air, hot day vapour can linger for some time. Enough said.
11,955
16,570
Just out of interest, a question for those with fridge automatic changeover, I can understand it changeing to 12v when the engine is running, but when it reverts to gas afterwards how does it activate the igniter? - as our manual start needs us to hold in the knob to activate the igniter.
Geoff
It is simply automated. Holding in the knob on any gas appliance opens the gas valve. Once the flame failure device kicks in the knob can be released. To automate that the gas valve is opened electrically for a fixed period then the FFD kicks in as normal. If the fixed period is exceeded and the appliance fails to light the sequence is repeated. Usually 3 attempts are made then the appliance indicates that it has failed to ignite & shuts down. A Truma, Alde, and your domestic boiler all work in the same way.
11,955
16,570
You have a Thetford fridge.
7,513
19,945
Lanzarote
Nil by mouth
Lots
If we turn off the gas, how can the missus do my a fry-up on the move?
Full English and 3 or 4 pints sets me up to drive all day :)
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
We only turn ours off when refilling. Its laziness I know.
Reactions: JJ
TerryL
6,188
8,190
North East
Low Profile
Understand your concerns @JJ but I'm not aware of any such "explosions" ever being reported. Same as the mobile telephone warnings garages display - it's never happened.
Unless someone knows different? I'm happy to be enlightened.
Reactions: JJ
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
How would you use the kettle on the hob when you're driving if you switched the gas off ? It would be too difficult to lean out and switch it on whilst on the motorway.
