Dometic 3200 freshjet is tripping 10 amp (1 Viewer)
Sep 15, 2021
101
11
Just looking
Any idea why this is happening with no other devices other than wifi turned on
10amp should support maybe 2000 watts and aircon seems to pull about 1500?
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
we are still learning
Double check that the charger is not supplying full charge at the same time as your Domestic Air con unit working and or the water heater is on . Just a tad too much sometimes.
Kev
L
Sep 15, 2021
101
11
Just looking
Kev
Many thanks Kev - how do I check that?
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
On hook up...does your charger come on automatically or can you switch it off at the box? If so ..Switch it off and then check it. If it works ok ...Problem solved. If it still shuts down...it has to be the Domestic Air con unit pulling too much current to fire up (Start) as Lenny has stated.
Kev (y);)
Nov 14, 2018
1,050
2,409
Europe
Just sold
since 1996
I know little about electrics but the 3200 does require 10 amps. If it’s an older model without ‘soft start’ perhaps on startup its requiring more than a 10 amp supply?
Oct 26, 2014
1,872
3,201
Dumfries and Galloway
Pilote P696GJ
According to the specs the 3200 requires on cooling mode 1300 watts of power
and does have the soft start incorporated
Watts = Amp’s ➗ 230v = 5.65 amp so should be more than capable on a 10 amp hookup
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
Typical starting load can be over 4 times the running load. For this reason there is a time delay built into the trip. If the trip is of the wrong type, or faulty, this may explain the problem. Soft start only reduces starting load, but in so doing it increases the duration of the high load period.
L
Sep 15, 2021
101
11
Just looking
Brand new with soft start
scotjimland
2,338
10,132
A Woosh bang
Watts = Amps X Volts .. 1500 watt at 240v will pull 6.25A ..
yes, 10A is more than plenty
10A will support 2400 watt
scotjimland
2,338
10,132
A Woosh bang
That may be so but it doesn’t change the formula W. = V x A
