Many thanks Kev - how do I check that?Double check that the charger is not supplying full charge at the same time as your Domestic Air con unit working and or the water heater is on . Just a tad too much sometimes.
Kev
On hook up...does your charger come on automatically or can you switch it off at the box? If so ..Switch it off and then check it. If it works ok ...Problem solved. If it still shuts down...it has to be the Domestic Air con unit pulling too much current to fire up (Start) as Lenny has stated.Many thanks Kev - how do I check that?
Brand new with soft startI know little about electrics but the 3200 does require 10 amps. If it’s an older model without ‘soft start’ perhaps on startup its requiring more than a 10 amp supply?
Watts = Amp’s 230v = 5.65 amp so should be more than capable on a 10 amp hookup
its 1300 watts of cooling power according to the specs i believeWatts = Amps X Volts .. 1500 watt at 240v will pull 6.25A ..
yes, 10A is more than plenty
10A will support 2400 watt
