Does LPG burn hotter than Calor Gas? (3 Viewers)
May 7, 2011
5,960
31,691
East Anglia
Kontiki 669
We had gaslow fitted last week,and this morning we used the Motorhome for the first time to cook
breakfast and have the heating on.:)
My question is does Lpg burn better than Calor gas as the Motorhome seemed to heat up quicker and
I cooked breakfast alot quicker than I normally do!:)
Or is it just my imagination?o_O
GJH
29,450
38,827
None, now sold
2006 to 2022
I've never noticed it. Mind you we used Calor in our first van and LPG in the current one so not a true comparison.
I believe butane burns hotter than propane as toast does better on one of those stand up wire toasters on a butane hob.
Jo662
May 7, 2011
5,960
31,691
East Anglia
Kontiki 669
I think what the OP is querying is the potential for a different mix between Calor and Autogas, which might make one burn hotter.
Yes thats exactly what Im asking!:)
53,454
150,112
Calor can be either Butane (blue bottle) or propane (red bottle), Propane used to run hotter as it was run at higher pressure. Now we run both at 30 mb Butane has a higher calorific value therefore it will run hotter.
However we need to take temperature into consideration, Propane continues to gas of down to -40, Butane stops gassing off at 0 deg., in practice Butane is almost unusable below about 5 deg and in practice flow rate starts to drop around 10 deg, so at this time of year Propane will out perform Butane.
Autogas in the UK is 100% other countries it is a Butane/Propane mix depending on time of year.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Would this be the reverse then. As Autogas is propane?
Jo662
May 7, 2011
5,960
31,691
East Anglia
Kontiki 669
Ok,well mines hotter anyway!:rofl:
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
For info. calor gas sell both propane and butane and autogas. but autogas can be a mix of both. It is worth noting that a lot of people are using butane regulators 28-30mb with propane. Propane regs and normaly 38mb. So if you please check that the reg. is the right one. It is also quite possible to have a propane reg 38mb on butane. This will give out more heat. but may course problems
ubuntu1
155
44
Derbyshire
since 2006
Since 2004 all motorhomes have to run at 30mbar across the whole of Europe. As described above autogas is just a butane/propane mix and Calor is either propane (red cylinder) or butane (blue cylinder). The calorific values differ but for most of the year there is little practical difference. In winter you need propane.
Emmit
8,034
17,754
Pilote Explorateur
Jan.2014
Just for info.
I have in the past used a cylinder fitted with a Butane Reg when the cylinder had propane in it.(Don't Ask)
It seemed to make no difference whatsoever despite the supposed difference in assumed pressures.
I would add that this was on an outside gas hob being used outdoors.
denisejoe
5,619
12,051
Warden isle of sheppy
For the last 40 years we've been using Butane and Propane Calor Gas cylinders and as far as I'm aware there is no way you can run a butane cylinder on a propane regulator and vice versa.
Joe
53,454
150,112
Joe
Why not, providing you have adaptors, we all now run both at 30mb, a bit low for propane & slightly higher than the old butane regulatrs.
