- Mar 14, 2019
- 1,124
- 1,123
- Elddis Autoquest155
- Since 2018
I adapted my motorhome to do as DOJC states as the connection for the hose was well under the side skirt and a right hassle to get to. I adapted a hose connector plate which looks like those used for EHU’s on the van so that it uses the original bayonet type connector for the 40mm pipe supplied. This works a treat having used it for whole season. I discovered that the fresh water tank has the same hose connection system underneath the skirt but as it is fresh water I just drain it when need be usually onto the front garden next to where I park.So 10% of your sh!te gets blasted over the guy behind!! Love the idea!! Where can I get one fitted!! And can you get one that varies the percentage?
On the main issue, I got a supplementary side hose fitted to the grey tank so I can attach a hose to a grey water disposal point. This also means I can direct the grey water straight down into a roadside drain if I need to, but I haven't had to yet.
