A Poorly Secured External 12v Socket! How to Correct?
Bridgend, South Wales
Just started!
I believe this socket provides 12v to a Whale Superfil Water Pump.
As you can see, It's not fixed to the van very well and over years several additional attempts have created more holes - presently I think there are six and it's still hanging off!!
Any way, I have a new socket and wonder what's the best way to fill the old holes, make it look nice and clean again and maybe even use two of the old holes to secure the new socket. Any suggestions?
I would move it away from the damage, a bit of fibreglass matting on the back side to fill the void and then body filler and a top coat.
No point trying to fix back there if it's failed 6 times.... Obviously a very thin area of body work.
Or perhaps use a special plasterboard fitting that splays in the void and gives a star shaped multi 'anti pull' load spread
Steve
You could clean up the area and glue on with ebt glue or 3M 5200.
Then it won't ever come off or leak!
Cheers James
Cut a nice disc out of some decent white plastic and stick it over the damaged area.Fill the back in with some epoxy resin and then fit the socket back.finsh the edges with a nice bread of white mastic sealant.job done and cheap as chips. (y)
Thanks everyone, some good ideas :)
I have some Sikaflex EBT so will likely use that in combination with another suggestion :)
Remove the screws, stick on socket with white CT1 covering all the old holes, wedge into position with a stick or similar for a couple of hours until CT1 has set. Run a nice neat bead of CT1 around the flange and squirt some into the screw holes then gently refit the screws. Remove all excess from around screws. Job done.
Strangely I have CT1 in stock too - I never know which is the best adhesive, there are so many to choose from!
As for laying a nice bead, I've never been successful at that and usually end up getting it all over my hands and clothes :)
Haha, don't use too much and always use the cleaner/solvent stuff, Multisolve I think is called, it allows you to get a nice smooth finish 👍
I know a mastic man (all he does is apply silicone and mastic to new build houses) and he swears by water with a dash of lemon fairy liquid rather than licking your finger. The mix should feel slippery.
He would normally apply mastic then spray with the mixture and remove excess with a piece of shaped wood or for smaller areas his finger.
Exactly that but you can't use water with CT1, the solvent replaces the water.
