A class and coach (2 Viewers)
Oct 22, 2019
1,601
4,480
Hampshire
Chausson 640 welcome
Since October 2019
It’s a moot point as I’ve a new coach built - and I love it but I never been in a A class . I can appreciate that the A class can probably make better use of space (because it’s not fixed to a can base) - but what , fundamentally is the benefit ?
stiffer chassis ?
More “solid” feel?
just intrigued and not wishing to start a then and is war . (I do this the a class look nice though )
Jewellbags
Oct 22, 2019
1,601
4,480
Hampshire
Since October 2019
I could understand that. No cab to “bolt into “
53,476
150,187
Cab much more spacious, great views through the big windscreen and larger side windows, cab better insulated, less road & engine noise.
Great driving position, easier to manover in tight spaces due to flat body sides & to reverse. Most have a double floor for storage and better insulation, fully winterised.
May 29, 2014
2,054
1,661
southampton
A frame
since 1985
stiffer chassis ?
More “solid” feel?
Snob value?
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
The chance to be driven mad by trying to do ANYTHING under the hood. A class have got a letterbox slot that allows you to do nothing with ease, even topping the oil up is difficult.
Apart from that if it is newish then it is lovely to be inside and not worry about 'under there'.
19,368
30,326
The chance to sit a long way from the front of the vehicle.
As Lenny says the position is actually the same as it’s dictated by the dashboard position on the chassis, unless of course you buy an A class on IVECO chassis and then most of them have the dashboard raised and moved forward so that you sit much closer to the front than any coachbuilt.
43,332
49,505
Better insulation, better view out the front, better integration of the cab into the living space,
A lot less passenger protection in a frontal or front side impact.
All the metal is removed and replaced by lightweight materials, fiberglass and ply/foam etc offering next to no impact protection.
19,368
30,326
I said that a long time ago and got shot down in flames.
It was said some makers move the bulkhead, steering wheel and pedal box further back.
To this day I can't see how this is possible.
It is possible and is usually done by a specialist chassis engineering company, Meier in Germany do the chassis prep for MORELO and PhoeniX, Concorde do their own and I can never remember who does N+B but they are Dutch.
If you look at MORELO you will see that the original dash is completely removed and rebuilt into a bespoke Fibreglass moulding, this does all make the vans more expensive though.
43,332
49,505
And the steering?
Unless it's a steering box and drag links that can't be moved.
11,955
16,570
All they do is move the windscreen forward over the engine. There may be some liner-class that move the controls but it would be a very costly exercise for little gain. What I really like is the luxury size drop-down, ready-made, bed. My wife uses the similarly ready-made fixed bed at the rear. Bed-time conversations are a bit difficult as apart from the distance there are two sliding door sets in the way too.
Rosemary1
1,427
4,152
Dumfries and Galloway
Rapido A class
1 year
We really like the improved views while driving, it just seems to be a lot clearer for watching other traffic etc and using the mirrors.
Don’t like - any work involving lifting the front bonnet
Jun 10, 2010
8,519
20,233
Shrewsbury (sometimes)
N&B Clou Liner MAN
My N&b arto isnt too bad for access actually and we dont get the leaking scuttle problem suffered by the ducato coachbuilt.
I can also spin the driving seats around easily and open the big side windows without the key in the ignition.
Steve N Tracy
1,235
3,728
Southampton
4 Years
As well as the better insulation, a slightly better payload the doors and other steel bits on a coach built carry a weight penalty.
bobandjanie
8,164
15,811
Javea, Spain
Pilote V600g
Must admit when we had our a class eura mobil, one of the things I was not over impressed with was, the front seat belts were only attached to the seats, don't know if all a class are the same. ?
And yes I would recommend a factory tour, you will then know why you have such a job removing anything, ? they build them from the inside out. ? Bob
