2005 Ducato jump lead attachement. (2 Viewers)
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
I always keep (but have never needed) a set of jump leads in the van, should I or someone else gets stuck. Whilst putting them in the locker ready for our upcoming jaunts I thought I'd have a quick look where I would put them in the event where I did need them..........
Where the hell do you put the positive lead on a 2005 2.8 JTD Fiat Ducato?????? The positive on the battery is buried way back yonder and covered by loads of bits and bobs - hideous.
Any photos of where the positive can be connected? Knowing Fiat (bless them) it's remote but hidden from everyone all bar a technician that would fleece me...:Angry:
Regards,
Trikeman. :winky:
17,635
43,358
from memory theres an insulated terminal near the radiator. unclip the cover to use but be careful not to short anything from it to earth
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Pretty sure there isn't one. The jump terminal appeared on the X250
This was only because the starter battery is not in the engine bay but under the cab floor
32,667
66,612
Be VERY CAREFUL if you ever offer to give someone's vehicle a jump start - you can do SERIOUS DAMAGE to your OWN vehicle's CPU if you do ... even if you do it correctly! :whatthe:
We were told this by an AA man last year who came to get the next door neighbour's car going as her battery had gone totally flat, fortunately he arrived before hubby had a chance to get our jump leads out so we avoided any problems, but the chap said it is very common for someone to fry their own vehicle's electrics by doing so! :Eeek:
43,332
49,510
yes, the ecu can be spiked but if the ign is off on the 'invalid' car when connected and the 'doner' car is run for 5 or 10 minutes to put some charge in the dead battery before attempting a start then all should be fine.
Its the sudden power surge from the doner car into a flat battery while the ign is on which causes the damage.
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
I've had this problem in the past Kev,if yours is the same as mine you can unclip the offending cluster over the positive lug.
It is awkward as there still remains a bundle of wires you have to manhandle out the way.An easy solution to this is to fit a Spare tail off the positive to aid any jump starts in the future.
Vlad
13,087
101,475
Bolsover, Derbyshire
Hymer S800
not long enough
we have a Mercedes so this may not help, but we needed a jump start and had to call the RAC, our battery is under the floor so I wondered where the connection would be made
On our engine we have a red and black plastic round disc that both push back to leave a pillar, I would never have thought to look or even know what they were till I saw them used
You might be as lucky on your Fiat hopefully
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
I have the same set up as you I think, and yes there is a common positive 'rail' under a plastic cover. Be very carful as there is little room.
And as has been said above and others NOT a good idea anyway because of the damage it can do. Due to the (back emf) when putting on, or more so taking off the leads.
Steve
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Vlad
Hi Vlad,
cracking idea - will be onto it tomorrow. Thanks to everyone else too - why can't vans be like the good old days, I just had a look in the handbook and it is full of 'don't do this, as this could happen - don't do that as this could go', etc etc etc.........
:Angry:
It looks like the only safe way (should you ever be stuck with a flat battery) is to connect up and build the charge up.
Regards,
Trikeman. :winky:
Vlad The Impaler
1,633
2,227
Rutland
I park my van at the side of the house with its arse nearest the road.Cant get another vehicle close enough to jump it,if I have any trouble I disconnect the battery from my work van carry it to the front of MH connect jump leads to tail and hey presto.
No running engine,alternator,power spikes, simple :thumb:
Vlad
