Wiring a battery charger and inverter thro the van ring mains? (1 Viewer)
MobyDick57
108
145
Scarborough
Morelo Loft 78F
Started 2012, 1st Burstner Ixeo it720, 2nd Carthago C-Tourer i150:)
Good afternoon:)
Unsure if I have set my first thread up correctly:)
I have been thinking how can I wire the battery charger and inverter, so that the inverter feeds the van ring mains without effecting the battery charger ( ie so there is no loop).
Should the wiring of the inverter be as follows;
Mains hookup through 240v multiple fuse box.
A 240v supply cable to the Inverter with auto mains switch.
A separate 240v supply cable to the Battery charger - Votronic Triple charger
Inverter
It receives power from the 12v battery and directly from the hookup.
It supplies the ring mains.
Therefore
When the van is on hookup - the inverter automatically switches to mains to supply ring mains. The battery charger receives a separate supply to automatically charge the batteries.
When the van is NOT on hookup and the inverter is on - The ring mains receives 240v mains, however the battery charger DOES NOT RECEIVE 240v mains. Therefore absolutely no possibility of a loop.
Does the above make sense?
or have I got wrong?
All help will be much appreciated:)
43,329
49,446
On inverter just turn the charger off, if should have its own protective breaker in the consumer unit. .
If it can't be turned off you need seperate sockets for the inverter.
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
Hi papajohn,
On my morelo switches automatically, so I do not have to switch anything.
However we also have a camper van and I want to automate it the same:)
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
My Morelo is wired in a similar way.
Ie imagine an extension lead with two sockets. Plug in the EHU
One socket goes to inverter then ring mains
One socket goes to battery charger (not ring mains
Unplug the extension lead, the inverter switches to DC
plug extension lead in, both get separate 240v
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
Simply interrupt the wire that supplies your 13 amp sockets, and have that as the "input" to the inverter and the "output" re joins the wire (so the inverter is series with the sockets
If it doesn't have a built in automatic transfer switch, use an external mains relay or, buy a switching box.
Don't forget to add a RCD on the output of the inverter as the 13 amp sockets will be post the RCD fitted by the motorhome converter
Or, buy a inverter/charger, and put in series between the 16 amp hook up socket and the distribution board and unplug the existing charger
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
The inverter is a Votronic 1700 with automatic switching and a RCD.
The battery charger is a Votronic triple charger.
4,471
7,957
Salopia
Duro 6x6 Overlander
since 1968
These work well , for auto switch between supply , and can be manually switched as well , just connect charger on 240 ehu side and inverter to other input , ring main sockets to ouput
3,587
7,776
Amersham
van conversion
Since 2019
Surely that first phrase is wrong. It it a inverter charger. The input and output is separated until inverter synchronising with the grid, and then it closes the relay to put output in parallel with the output of the inverter. You can’t energise the output from the same source of input.
Op needs to clarify if he is talking about inverter as separate stand alone 12v feed only, or a inverter charger with AC in.
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
Yes inverter has 12v DC and 240v input:)
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
The triple charger has solar/alternator/240v input:)
11,187
17,834
HYMER B644
I’ve done it many ways in the past.
Manual switch
Relay
contacter
currently working on this
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
No I was giving the options as I wasn't quite sure which vehicle we are now talking about LOL
If its just an inverter, simply fitting it in series for the 13 amp sockets is the easiest, so an inverter with a built in transfer switch is the easiest DIY install
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
In my case my fridge is 12v only, so no fix units use 240v:)
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
Eddievanbitz thanks, I not technical but is that as described in my first post?
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
Thanks very much Eddie:)
And thank you everybody else who joined in with this discussion:)
I tried to find a wiring diagram on the internet, but to no avail. In this day and age it should be simple to have the above wired automatically without the mystery:)
Thanks again
Richard
6,872
7,992
Manchester
A class Hymer
Since the 80s
I'm not convinced that this inverter has an RCD. It has overload protection and automatic switching. So you will need an RCD or RCBO on the output. Also it's either/or. You can't use the inverter to boost the mains supply like some Victron inverter/chargers for example.
I suggest two RCBOs in the mains consumer unit, one for inverter loads, one for non-inverter loads. Hookup input goes to the non-inverter loads RCBO, and also to the inverter mains input. Inverter output goes to the inverter loads RCBO.
Non-inverter loads include the battery charger, 3-way fridge, water heater and room heater. You don't want the fridge to be running from the inverter, draining the batteries.
The inverter loads will be automatically switched to hookup power when available by the inverter internal relay.
I suggest using RCBOs (ie combined RCD and MCB) because you need two RCDs anyway (for hookup and inverter). Also in the UK it's a bit difficult to find 2-pole MCBs that are required by the regs rather than the common single-pole type.
An RCBO is a bit more expensive than separate RCD and MCB, but since only two are needed (not as in a house which would need a dozen) that's not a big deal.
11,187
17,834
HYMER B644
Just be mindful of AbSorbtion refrigerators if they are on the same circuit as your ring main. AES versions will switch to your inverter and drain your battery.
MobyDick57
MobyDick57
108
145
Scarborough
Morelo Loft 78F
Thank you for your help:)
I am having the inverter replaced due to be faulty at SMC. We have agreed to upgrade the unit to a Votronic 1700 model, However I want the wiring to be automatic ie not have to switch from inverter to EHU plus avoid another switch to avoid a loop.
Thank you everyone:)
Rustyspanners
53
79
You need a priority relay £70 automatically disconnects from ehu when on inverter. Connect charger on ehu side so it gets no feedback power from invertor.
