- Oct 25, 2016
- 5,586
- 31,635
- Bailey Autograph 79-
- Lots but slow learner.
Yes a itsy bitsy teeny weeny 750 twin. The baby brother to the Africa Twin.But is there an engine under there somewhere?
Modern electronics are a nightmare to diagnose. An example, on older boilers if the fan didn't run it was easy, has it got power? yes then it's a faulty fan.....no power then it's a PCB fault. Move on a bit in time and now if a fan is faulty the PCB will know and won't send it any power. After this change all diagnostic procedures had to change. It's far more complicated than it was.Sorry If I am wrong or missing something on The Wing not starting, but even if the fuel pump was kaputt, why did the engine not turn over on the starter?
If the engine turned over on the key, and then did not start, then one might look at fuel starvation or ignition electrics etc
How could they possibly know it was the fuel pump, without the engine not turning over trying to fire up?
LES
Quite like the look of the X-Adv, maybe something ill look at when i decide to diwnsize.This is the other plastic bike, bit less of it than on your Centauro.
Never had a Guzzi. Had a tour of the factory a good few years ago.
View attachment 774574View attachment 774576
Honestly i was so surprised when i rode it.Quite like the look of the X-Adv, maybe something ill look at when i decide to diwnsize.
Certainly with boilers and I expect it's the same with most stuff, diagnosing is centered on questioning the PCB, however the answer will normally only be able to point in a direction of a fault, rarely can it identify a component fault. Another example from a boiler, modern boilers have air flow sensing and if faulty the pcb will be able to tell you that there is a problem with air flow but we then have to find out 1) is there a blockage 2) is the fan running at the correct speed 3) is the sensor faulty 4) is the PCB faulty 5) is it a wiring fault. Add to that every component is expensive and the customer will not pay if we order the wrong one, it's not easy from whichever side of the counter you are on.Yes. I can well believe that the ECU tries to turn on the fuel pump to prime the system, and when the pump fails to run the ECU won't let you crank it as that would be pointless and drain the battery. Is that the case on this bike though? Dunno. But a dealer should have diagnostics where the computer will tell you why it is refusing to go. Perhaps it was pointing to the fuel pump, but the problem is actually in the loom between the ECU and pump. Really could be anything.
Hi Bobnick, if you are looking for a goldwing guru you could call Dave Partridge at AwingAway in Telford.Honestly i was so surprised when i rode it.
Got plenty of go in it for me at my age (i still like to play and chuck it about)
I can sit on it and ride in one go longer than on the Wing.
I have done a bit of green laneing
It's doing 75.5 mpg
Got 4 modes in the DCT
It's confused all the punters as they are struggling to define what it is, a scoot or a bike. I've decided it's deffo a bike.
It ticks a lot of boxes.
I love it so much i don't need the Wing.................even when it's running
Might get a retro modern to go along side it. Fancy a CB 1100 like i had before.
Thanks for that.Hi Bobnick, if you are looking for a goldwing guru you could call Dave Partridge at AwingAway in Telford.
If he canāt fix it no-one can!!!!!
Alex W (goldwing rider)
Bob and if you come to Telford as previously discussed I have overnight parking with all facilities or an en suite bedroom + of course the use of the garden barThanks for that.
I am commited at the mo as the bike is with Bill Smiths.
The name has gone in my little blue book.
Hope the room has a nice radiator in it to keep me warmBob and if you come to Telford as previously discussed I have overnight parking with all facilities or an en suite bedroom + of course the use of the garden bar
If I pretend to have a Wing, can I come too?Bob and if you come to Telford as previously discussed I have overnight parking with all facilities or an en suite bedroom + of course the use of the garden bar
Wot a very nice manBob and if you come to Telford as previously discussed I have overnight parking with all facilities or an en suite bedroom + of course the use of the garden bar
You are NOT sleeping with meIf I pretend to have a Wing, can I come too?
The only funster i have met and chatted to. And yes he is a nice chap in a nice way.Wot a very nice man
My progress to date, going to bury the pipes that the builder in the 80ās didnāt seem to think was a good idea. I have another radiator hung just need stepson to re plumb and then patch the wall. Ho wouldnāt do it in the winter in case he encountered problemsHope the room has a nice radiator in it to keep me warm
A very gracious offer, thank you.
I may be acquiring a spares or repair one soon that needs a bit of work but will fix it and sell on at a big profit, let me know if you are interestedIf I pretend to have a Wing, can I come too?
Your not going to make much after giving me Ā£20k for it thank youI may be acquiring a spares or repair one soon that needs a bit of work but will fix it and sell on at a big profit, let me know if you are interested
Solid lump, well under strained.Yes a itsy bitsy teeny weeny 750 twin. The baby brother to the Africa Twin.
Do you ever use the kill switch Bob? If not then it's likely got some oxidisation around the contacts, a good squirt of contact cleaner and switching it on and off a few times might get it working again.I don't believe what i have just heard on a telephone call from Bill Smiths Honda.
"It's the kill switch Bob."
Well i was speechless. How long have they had the bike. I know nowt but i would have started there.
Unbelievable.
Ordered a new one that will be coming from Belgium, Ā£545. Pay up front it will be here on Friday.
Spanner monkey don't work Fri Sat Sun And Mon (good job eh) so Tuesday it's his first job to put it back together.
I'm going for a lay down.
Never ever used it on any of my bikes other than by accident.Do you ever use the kill switch Bob? If not then it's likely got some oxidisation around the contacts, a good squirt of contact cleaner and switching it on and off a few times might get it working again.
I know one thing I doubt if i'd ever use Bill Smith for any work on a bike of mine.
Ah but do they come from Belgium
