Wind blocker awning sides
Lanerboy
midlands
Carthago 4.9 superior
We have a thule 6200 awning on our carthgo and i want to buy some of these mesh type light weight sides to keep the wind out.
I have been told about some called lillypad now do i need specific ones for a thule awning or are they all the same fitment.
Also is this the only make available or are there others
Check their website but ring them up and ask
They are very good and everything is bespoke to your motorhome so they can produce what you need
Website says they no longer make bespoke awning rooms
Give them a call, you'll find them very knowledgeable and helpful.
As mentioned http://windblockers.net/
Some other ideas here https://www.motorhomefun.co.uk/forum/threads/sun-blocker-idea.214418/#post-3742535
We had the Fiamma version (available in various sizes so can use partial or full width of awning rail) which we preferred to the Lillypad Windblocker nets although more bulky https://www.motorhomefun.co.uk/foru...view-xl-alternative-for-awning-screen.133400/ . Both Fiamma & Thule do a solid sheet option both called Sun Blocker.
Fiamma Sun View (gives some privacy but can see through & some air flow) with ladder straps on ends to keep the rope ties clean & angle them to expand the area inside the awning:
Depends when you want them Shawn.
Obelink in Holland are cheap for the Thule blockers and they also have their own range.
They deliver next day if you order early enough.
