Repaced my 5 year old Varta leisure battery with the same model as fitted (LDS105). The van is in indoor storage and was on hook up with a smart charger connected. I turned off the hookup (and therefore the charger) before removing old battery and fitting new battery. What I didn't know one should do, is to remove the fuse to the solar panel.
Is it likely that I have damaged the solar panel (or blown the fuse) by connecting new battery without disconnecting the solar?
As van was indoors didn't even think about the solar panel. Only realised I should have when following a thread about changing leisure battery.
If solar fuse has blown, where is the fuse likey to be fitted? And what value will it be?
Thanks.
Thanks.
