What's a "high sided vehicle"?
Ayr
Newbie
I live not a million miles from the Erskine Bridge and the Forth Road Bridge, both of which are frequently closed to high sided vehicles and since buying a campervan, I realised that I've no idea how a HSV is defined. How high is "high"?
Tim
If it blows over in strong winds its probably high sided.:BigGrin:
I would say anything bigger than a panel van, transit etc
Seems im wrong by definition
copied and pasted
noun
(British) an official term for lorries, vans, trailers, etc with a height greater than that of motor cars
Colins Dictionary
there is no legal definition.....
a fully loaded 44 ton artic 'box' trailer will not be blown over as easily as a 3.5 ton motorhome
and a trike will not be blown over as easily as a motorbike.
common sense prevails :thumb:
could be wrong but curtain side artic trailers are a lot more stable than rigid sided versions due to the sides 'flexing' and allowing a little 'give', absorbing some gusts in a cross wind.
there is no definition.....
[HI]could be wrong but curtain side artic trailers are a lot more stable than rigid sided versions due to the sides 'flexing' and allowing a little 'give', absorbing some gusts in a cross wind.
[/HI]
No no no
The curtain acts as a sail, you can never get them really tight and they trap wind at the ends,
Its the curtain siders that get blown over the most, I have dragged a 16ft high double deck trailer over the howden flyover on the M62 in high winds, my arse was nipping a bit :Eeek:
all i can say is a mate last winter was at silves in a carpark when a tornado decided to blow by . 7 m,homes on their roofs .his iveco luckily got tangled with a tree . the m,homes werent exactly high but were smashed to bits . glad i wasnt there.
just a reminder vehicles over 3metres must have their height displayed in the cab so the driver as a good idea of height.lots are over that height but arent marked
Thats correct
And you know the firm i was dragging these 16ft high trailers around had a couple of units with no height chart in the cab :Eeek::Angry::Eek!:
if the truck isnt correct i wouldnt drive it .
but didnt the trailer have a marking and stating height with a such and such pin height ?
if i was working for a company that wouldnt change their views i would whistle blow . companies like that need reporting .
I have an A4 laminated card with safe height and actual height, safe width and actual width.
if my safe height is 10ft and actual height is 9ft 6in i know i can get under a 10ft bridge...but any less than 10ft and i would start thinking twice.
:Laughing:
Okay, to put it another way, if a bridge is closed to high sided vehicles, would it be fair to assume that it's closed to campervans too?
Tim
if the wind speed is high enough it will blow anything over.....:Eeek:
Broken Link Removed
Went over the Humber bridge from the Lincolnshire side (all toll boths on the Yorks side) when the ' no high sided vehicles' signs flashing in a 7.5 t curtainsider 3.5m high...slowly but no problems. Single decker buses going over same height, when I get to toll booth get earache from operator, did you not see the signs, so I said what do you want me to do, go back again !!
On the M62 when windy near jnctn 22 at the top of windy hill the signs would come on westbound for a diversion that took you over a road with a stretch that was like a wind tunnel...they don't do that now!!
As has been said a fully loaded high sided truck is a different beast to an empty one and driver experience is invaluable. Basically slow down but in extreme situations even stationary vehicles will take off.
