What Tools and other bits to take? (1 Viewer)
Jul 29, 2007
6,553
39,722
Ipswich
RV and PVC
30 years
Hi guys been trying to decide what tools to take in our new PVC, unlike the RV which has had me loading it up over 15 years and now has enough to function as a garage I want to carry just enough for minor repairs, to that end I have allowed myself a small tool box and the tray under the drivers seat, so what to take?
Already in the box assortment of screwdrivers, pliers, side cutter, long nose pliers, hammer, lump hammer.
Adding: two small adjustables, mole grips, small socket set, Multimeter,
Other bits: Gaffer tape, electrical tape, scotchloks, assortment of fuses, few metres of wire, set of bulbs for the van.
What else would any of you recommend?
old-mo
Extra Special
16,343
93,693
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
This is all I carry, Ian....... (y)
And this...
....................(y)
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Binding wire, a tin of gum-gum and an empty tin can for exhaust repairs. Mind you, exhaust systems seem to last a lot longer these days. Don't know if it's still the case but replacement exhaust systems for RHD vehicles were difficult to source in mainland Europe.
53,590
150,648
Sounds about right to me just add cable ties and a multimeter.
I like to have enough stuff to do hab repairs, I don't worry about the engine side too much as when modern engines go wrong you are normally stuffed.
Mar 30, 2019
1,089
1,380
East Sussex
Trigano Tribute
Since 2017
Assortment of small screws for when things might come loose.
And for the spectacle wearers one of those little screw driver sets you get in Christmas crackers really handy for tightening those loose arms.
Coolcats
5,960
9,985
HymerCar Ayres Rock
Gaffer tape, cable ties, multimeter, multi tool, couple of screwdriverS flat and Phillips and Breakdown membership.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Take several H4 and H5 hex bits. You'll lose the first ones and need the second ones. Oh and replace the ridiculous supplied wheel brace with a decent 600mm+ breaker bar and a 19mm socket and make sure they work for you before you leave.
olley
Jul 29, 2007
6,553
39,722
Ipswich
RV and PVC
30 years
Unless theirs a secret hiding place I don't have a spare, so no point in worrying about a wheel brace, tyre company can sort that.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
I also didn't have a spare. But then I had a screw into my tyre on a Sunday in Devon. Only KwikFit open and they couldn't work out how to change the tyre. Apparently it has some sort of retention band. Luckily, the screw held out the several hundred miles back home. I now have a spare wheel. I just need to work out how to mount it, as the original mounting conflicts slightly with the LPG tank.
Coolcats
5,960
9,985
HymerCar Ayres Rock
Just another thought, if you maintain your MoHo, there is probably very little that 'should' go wrong therefore you need a minimalist tool kit
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Gaffer tape, Errr, Gaffer Tape, and Cable ties. And a roll of self Amalgamating Tape, for Emergency water repairs, other than that A recovery contract. (y)
Coolcats
5,960
9,985
HymerCar Ayres Rock
:nod: yes Gaffer Tape :nod: cant disagree with self amalgamating tape though, along with a recover contract....we all have our limits we just have to acknowledge them ;)(y)
53,590
150,648
Also worth carrying a couple of cam lock straps, on our first van on our first trip I ripped the bottom off the gas locker in Slovenia. Held it together with cam lock straps & Gaffa tape, it held until we got back to the UK.
Another vote for self-amalgamating tape used it last year to hold my waste pipe together after catching it on a high curb.
Jamesh
2,200
3,839
Van conversion
Caravaning since 2010
12v cordless drill?
I have a12v DeWalt drill in which the battery has died.
Has anyone converted one to run off a cigarette socket?
I have a long length of ciggie wire to use.
Cheers James
Dec 24, 2014
9,234
47,728
Hurstpierpoint. Mid Sussex.
Compass Navigator
12v cordless drill?
Cheers James
I think you'll find that the drill's current requirement will exceed the capability of a cig lighter socket, its wiring or fuse. On start-up with no load it will draw around 3 amps which will rise to 6 or 7 amps under load and up to 10 amps if the motor stalls when/if the drill bit jams in use.
