What size inverter? (2 Viewers)
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
I have just loaded the van with all my gadgets(notebook/phone/satnav/carcam etc ) all low power stuff plus all the 12v chargers.What size inverter would I need to charge them as dont intend to use any item more powerful than listed? I have a 600 cheap inverter already but would this use more out of the LB "s than say a 150 /300 inverter for charging same item?
43,332
49,494
The difference between the three sizes will be minimal really if you only use the listed items.
The inverter will only draw the amount of power it needs at any Given time for the load imposed.....plus a little extra for conversion losses.
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Don't use an inverter to charge your laptop. Instead just buy a 12 volt to various other voltages ciggue lighter socket powered transformer. ..loads on ebay or in many electronics shops. Check the DC voltage your laptop uses. Often 19 volts, and just set the output of the transformer to that.
That's much more efficient.
For the other stuff I'd have thought a tiny inverter would do the job, 100 watts or even less.
D
Deleted member 29692
An inverter is the most inefficient way possible to charge things like that.
You're stepping 12v up to 230v and then the chargers step that back down to whatever voltage the device needs.
From an battery efficiency point of view you would be far far better off putting in some extra 12v sockets (or USB ones depending on the devices) and using those for charging
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
If the above link doesn't show, go to Amazon and put in the search:
Anker PowerPort 60 W 6-Port Family-Sized Desktop USB Charger with PowerIQ Technology for Smartphones - Black
