Wet and forget (1 Viewer)
Bertie driver
7
Coach built
Neebie
I have seen on another thread that you can spray this patio cleaner on your motorhome roof to prevent and clean moss etc from it. Has anyone tried this. My fear is the chemicals might have an adverse effect on the skylights.
Sep 3, 2012
7,560
26,092
Cheshire
C Class Elddis 175
8+ years
I have just done my drive and decking with patio cleaner and its basically glorified bleach, wouldn't use it on my van. Any aluminium and it may react with that also.
elbow grease and a scrub with a car cleaning brush with wash and wax is best.(y)
I suppose if the moss is really bad , as a trial you could try a small area with a sponge ( wearing gloves)first to see if it made a difference.
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Have used Wet and Forget for a few years on drives and walls etc. Check their website to start with. I believe it contains no bleach or harmful chemicals. It works brilliantly on lichen and dirt etc BUT it doesn’t touch moss on my block paving.
Cheers
Bernie
icantremember
8,338
17,562
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Cheers
Bernie
I use Patio Magic on the block paving (NOT on moho) which works fine, if a bit slow ... have you found anything to kill the moss?
Feb 22, 2011
9,824
20,265
Newcastle under Lyme
Hymer B544 A Class
I buy a large drum of similar stuff from farm supplier, cleans the drive a treat but wouldn't use it on the van. I think it's intended for cleaning cow sheds ,!
Basically bleach
H
Hagstrom
I've used WetnForget on my van roof. Works fine with no adverse reaction.
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Soda crystals works for me. Cheap as chips. Sprinkle before rain!
ymfb
798
6,347
Salisbury
AS Kingham
If you are concerned about what it may contain ask for the COSHH data sheet
Jun 21, 2008
79
14
Haxey, Doncaster, UK
Eldiss CV80
I have been using Wet n Forget for the last 3 years and it has not done any harm to my Motorhome other than keep the roof 100% clear of moss and Algie it contains no bleach it’s non acidic and non caustic I would recommend this product to anyone of course that is my opinion
nJohn
Oct 14, 2007
4,002
6,265
Rochester
Auto-Trail Mohawk
16 fun filled years
According to their website it does not contain any bleach.
Is Wet & Forget Safe?
A great big YES IT IS!!
Just keep children and pets indoors while spraying and until dry.
Subsequent rainfall poses no issues.
Wet & Forget is non caustic, non acidic and contains no bleach!
It has a pH of 8. Tap water is 7!
Jan 24, 2010
2,440
4,850
Adria Twin
Not heard of this stuff before - would have saved me all hours yesterday day cleaning up the roof as the van is close to conifer and weeping willows and always gets algae and stuff on the roof over the winter - think ill be ordering some!
exerts from the FAQ
Wet & Forget can be used on an extensive range of outdoor surfaces including tarmac, concrete, decking, roof tiles, Astroturf, bowling greens, bricks and paving, canvas tents, caravan awnings, conservatories, fibreglass boats, greenhouses, golf greens, limestone, sandstone, marble, outdoor furniture, outdoor pots, outdoor painted surfaces, pool surrounds, shade sails, slate, tennis courts, yacht sails
And another bit from their web site
Wet and Forget is ideal for use around the home. It can be used on any outside surface. Cleaning anything from paths, patios, garden furniture, umbrellas, conservatories, greenhouses, fences and rendering, UPVC windows, all the way up to and including the roof. It can even clean your caravan, motor home or your car’s soft top.
Charlie
3,211
3,639
Herefordshire / Worcestershire borders .
Auto Sleeper Kemerton.
Im a newbie
On Motorhomes there are many combinations of materials and finishes on the materials. Then there are the often found decals that can be expensive to buy and can be impossible to obtain for older vehicles.
Clean your expensive motorhomes with the products designed to do the job safely. Other stuff is in my opinion just plain daft.
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
I can’t believe some of the suggested products here.... Truly lost for words.
I have much experience in automotive products that are intended for cleaning preserving and making look good.
None are mentioned above. Fact is MUCH damage could result.
Charlie, Just for clarity I said soda crystals for moss on my block paving and NOT for Motorhome!
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
So nice of you not to mention the proper ones given you have much experience :rolleyes:
43,359
49,641
I'm sure Charlie will have mentioned them in his other many detailing posts.
As he is no longer a subscribing member he won't be replying.
BriannYe
126
50,606
Southampton, UK
Dethleffs Pulse
Wet and forget is fine used it often when I had a caravan and a green awning that was ten years old. The results were outstanding without any problems at all.
Silver-Fox
9,274
29,165
Cheltenham Spa
Rapido
im a not so newbie
Would I use anything that isn’t designed for its intended use? Nope
