Water Tank Tap Valve Thingy ?? (4 Viewers)
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
I have 2 taps, fresh water and grey water tanks. They have MEFCO on the plastic
On the fresh tank, the blue handle has broken and needs replacing.
Have Googled and can't find anything :(
Any ideas ?
R
Robert Clark
Looks like a swimming pool valve
There are loads on EBay in different sizes
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
Ideally they need to have one of these on the end to attach the hosepipe :)
JFD
Apr 9, 2015
392
238
Crawley Down, West Sussex, UK
Pilote Aventura G730
since 2014!
It doesn't look like a OEM fitting - the jubilee clip and tape around one end speak to a previous owner's work!
As it seems to be a drain tap, which is usually only used during the winterisation of your motorhome, you could consider replacing it at the tank, so removing the need for a flappy bit of pipe hanging under your vehicle, ready to hit any bump in the road! You could even go upmarket and automate, rather than getting your hands dirty, with something like this:
Nov 5, 2013
3,103
97,865
Shropshire
Carthago chic e-line
3/4 solvent weld - 1/2 adapter
Nov 3, 2013
3,171
9,386
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Maybe, but need to get the water in somehow ;)
Hi,
Go uinder that bridge at Rouen,take the roof off........ If you take your shoes and socks off (You can now count up to twenty,the Navajo Indians taught me that trick when i was captured during my Pony Express riding days Yeeehar!...LOL)and work out the volume/cubic capacity of your now "Roofless" m/home......... HOW MUCH WATER DO YOU NEED?
Must go now,there is another 4 cartons of Conde Noble Vinho Tinto in the fridge,with my name on them...Hic...pardon.
Tea Bag.
PS. WHOA me dads horse!
Yorick
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
Sorry, I showed the drain tap as that was easy to photograph. I need the tap for the water fill, so needs the extension :)
17,630
43,340
what you actually need then is a replacement valve, which is a standard solvent weld one with a spigot on one end to attach to the pipe and a reducer to 1/2inch bsp the other, onto which the white hose connector screws. simple enough from a pond shop who will have the parts on the shelf or ebay
17,630
43,340
a temporary solution is to use a pair of water pump grips to turn the broken tap head
