Waste water ... blocked pipe (2 Viewers)
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Be careful if you use a plunger as you can 'blow' the joints with too much pressure.
GJH
29,450
38,827
None, now sold
2006 to 2022
Dont be tempted to use domestic drain ckeaners as they can melt the pipes.
That's why I only use Buster Plughole Sanitiser - and only started doing so after seeing a magazine article about it being tested on motorhome plumbing.
Feb 22, 2008
12,266
45,056
Nearly Tugging
so you don't fancy a transgender person poking something up your waste hole??
What do call the different ones , so many varieties, I suppose “It” might fit the bill ;)
Once upon a time it was boys and girls :rolleyes:
Apr 19, 2008
1,944
2,922
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
hot water and soda crystals,(baking soda) leave for 10 min then fill sink and try plunger,
Jul 24, 2014
1,101
2,792
North cotswolds
Peugeot Boxer Symbol Auto
since 2010
I have a drop down basin, the water tank got glogged up, very difficult to deal with but I had a drain snake from Lakeland which tickled the water flow back into action, whew, but I am so pleased to see this thread and take on board all the advice, future reference now stored.:smiley:
Oct 13, 2016
1,050
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
You're welcome, hope it works and the blockage doesn't have legs!
Cheers, Dave(y)
I must admit I did think of that last year when we parked up and winterised, I open all the valves and leave them open, including the waste tank, the outlet pipe is about 1.5 inches, so a mouse or rat could actually get in there ???
Apr 11, 2015
5,420
55,292
hull
Laika Ecovip 300
@movan I was gobsmacked at how much water had to go down before the tank started emptying. Could try leaving tap open and going for a run, look in your mirror see if you are dropping any. our 'empty' tank pours out when we go round a corner. Found out by accident when we left tap open after draining it, was on the way to farm storage thankfully not on a main road. I hate seeing waste coming out a moving van.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Yes one year mine was blocked by straw mouse nest .. fortunately not far in.
@scotzsue .. lol .. can't believe you put that on open forum .. I got told off once by a (thankfully lovely) Funster. . . But it is clean water. (y)
movan
movan
21,492
120,753
Moving around
Burstner
since07
I had really, really bad blockage in my house kitchen sink once ... my own stupid fault ..
Tried everything and cursing myself for oncoming call out charge from a plumber.
Googled... Scooped water out of sink. Covered plug hole with bicarbonate of soda and small amount of water. Then covered it in white vinegar. Nothing happened.
20 minutes later WHOOSH! It all disappeared .. :) The vinegar and soda cleared the lot.
Don't know if I would use in mh... would it affect pipes and joints...? Some people think so above, so maybe only if all else fails.
@bigalw35
Apr 11, 2015
5,420
55,292
hull
Laika Ecovip 300
Not like me i know am usually careful about what I post, the water would hopefully have been fairly clean as I sometimes empty a lot of the fresh water through the taps into the sink to flush pipes out befor laying up for the winter. We do use it over winter, but have been known to use bottles of water to save the hassle of draining down.
oops i am rambling. hope you get it sorted.
11,956
16,570
Will do. Funnily enough something happened last year and I meant to buy some thick electric wire to keep in van for such as this. A good reminder. :)
Spring curtain wire is good & works for sink & basin. It coils up small but needs storing where it'll dry.
11,956
16,570
Different plastics, my comment was based on experience. When I was helping a friend, all the pipes got very hot & soft.
So will domestic waste pipes if the cleaner is caustic soda based - it generates a lot of heat when added to water.
The Lobster
321
325
Borders of Scotland
Bürstner A576
Still getting started
We had exactly these symptoms... But it wasn't a blocked pipe ... It turned out that the rod that connects the waste tank valve to the handle had come away from its gear (we'd pulled to much instead of just turning)... Pushed it back in and the valce then opened ...'blockage' no longer there.
Aug 10, 2012
75
39
Worthing.West Sussex
Empty Nest
Tin or bottle of Coke.
If you can get to it disconnect the waste pipe where it goes into the waste tank.
It can be a bit "ugh" so have rubber gloves and container ready.
A regular dose of Coke (cheapest) down the plug holes seems to help keep the pipes clean.
Apr 19, 2008
1,944
2,922
Kent coast Hythe
Rapido fiat based
Should not create a problem for you ,if it takes the temperature of the hot water and clears within a reasonable 7.2 min then all will be well.
Also if the blockage is that bad sticking a bit of wire will clear a gap for the water to flow through is only temporary. Either way if the pipe needs replacing should be reasonable to do.
Ask at local college which teaching plumbing if a student is willing to tackle this task, under guidance of course from a tutor.
@bigalw35
@bigalw35
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Over a 20+ year period I have regularly used "Mr Muscle type" cleaners It dissolves human Hair which is the main cause of blockages. Commercial "PVC" pipework ( and I use the term as a generalisation) As they do come from differing sources. Will withstand this type of product, most where created with that in mind as the "general public" could not be trusted NOT to use the cleaning products they had been used to. Back in the 70`s we started to see welded "plastic" pipework for sanitary use on ships, they where abused by the use of all sorts of cleaners but we had less issues than with the old steel pipework. Most due the heat embrittlement in hot spaces. Imagine using Caustic Soda Mixed with Sea Water!. It was a great favourite with the stewards.!
Jul 24, 2014
1,101
2,792
North cotswolds
since 2010
Using any product not specifically designed for use on caravans/motorhome s etc should be checked out for suitably of their use, years ago when Mr Muscle bathroom cleaner came out i failed to read the small print, I liberally sprayed my bath and tiles, by the time the tiles were wiped the product had stripped the enamel coating off my old bath, a very expensive lesson.:(
bigtwin
5,244
9,948
Derby
Concorde
@movan , have you confirmed that it is, indeed, a blockage?
Adding more water didn’t result in any water coming out of the waste pipe?
Ian
movan
movan
21,492
120,753
Moving around
Burstner
since07
Ian
Hi Ian .. not managed to get back to the farm yet .. but hope to this week. Will let you know then. :)
movan
movan
21,492
120,753
Moving around
Burstner
since07
Ian
Yeah yeah yeah.... :) thank you .... yes more water ... big gush of water... :)
