Teasy2007
- Sep 26, 2007
- 2,086
- 1,159
- Carthago Malibu PVC
- Since 2005
Hi, Mike noticed something in his vision last Monday which just would not clear. On Wednesday I rang the opticians and they made him an appointment for the following day. The optician was excellent, explaining that we needed to go to hospital and she would make an appointment and call us later. She did and the appointment was for the following day!
We were surprised and didn’t really understand, everything was moving so fast. When we arrived at hospital he was seen very quickly, Mikes eyes closely examined and then told they would be operating straight away!! He had laser surgery and the consultant said he had a retinal tear, which if not treated urgently could have resulted in blindness.
Thank goodness we went to the opticians. Please if you have anything similar get it seen to straight away. When we got back from the hospital I looked it up on the Internet.
Detached retina (retinal detachment)
A detached retina is when the thin layer at the back of your eye (retina) becomes loose. It needs to be treated quickly to stop it permanently affecting your sight.
Get an urgent opticians appointment if:
If you can't get an urgent appointment:
Go to A&E or call 111 for advice straight away.
Treatment for a detached retina
You'll be referred to hospital for surgery if tests show your retina may be detached or has started to come away (retinal tear).
This will usually stop your vision getting worse.
What happens during surgery for a detached retina or tear
Recovery time after surgery varies. But as a general guide, for 2 to 6 weeks after surgery:
Important
Call the hospital or go to A&E if the pain, redness or blurriness gets worse after surgery. You may need further treatment.
Causes of a detached retina
A detached retina is usually caused by changes to the jelly inside your eye, which can happen as you get older. This is called posterior vitreous detachment (PVD).
It's not clear exactly why PVD can lead to retinal detachment in some people and there's nothing you can do to prevent it. But it's more likely to happen if you:
You can get a detached retina more than once. Get medical help as soon as possible if the symptoms come back.
Page last reviewed: 27/11/2017
Next review due: 27/11/2020
- dots or lines (floaters) suddenly appear in your vision or suddenly increase in number
- you get flashes of light in your vision
- you have a dark "curtain" or shadow moving across your vision
- your vision may be blurry
- your eye may be sore and red – take paracetamol if you need to
- you may need to take time off work
- you may not be able to drive
- you may need to avoid flying (if you have had a bubble of gas put into your eye)
Important
- are short-sighted
- have had an eye operation (such as cataract surgery)
- have had an eye injury
- have a family history of retinal detachment
) and also that he’s not had the gel replacement job so that’s good. Curious there wasn’t some sort of “trauma” that set it off. All the best and If I can help further just let me know
