V55/5 Help (1 Viewer)
twerly
38
71
Warwickshire
Hymer MLT 570
Hi Everyone,
just joined the MH community, very excited after years of camping and renting took the plunge last month and did self import of a Hymer from Germany. Fantastic experience , brilliant dealer, no hassle. Adventure driving home, NOVA all complete. Now stuck on drive until DVLA registered :Sad:
I have all the forms (CoC etc from Dealer), just trying to decipher them
Almost there, but just couple of questions I hope some-one can assist with
Tax Class - PLG (11) -is this correct ? (it is plated to 4250kg, but weight is 3150kg)
Manufacturer - Should this be Fiat or Hymer
Make - should this be Ducato MultiJet or again more about the Hymer
Model - again - not sure if this is Hymer bit
Type of Body/ vehicle - Motor Caravan ?
Type of Approval number / category - MISP ?
What is the CO2 for 2012 Hymer with Fiat 2.3 Multijet ? - for some reason not on the CoC
I have worked out / translated the rest (loooong evening)
Thanks for any help with any of the above :Smile:
Steve & Mel and Alex
17,635
43,369
Hi Everyone,
Manufacturer - Should this be [HI]Fiat[/HI] or Hymer
Make - should this be Ducato MultiJet or again more about the Hymer [HI]Fiat[/HI]
Model - again - not sure if this is Hymer bit [HI]Ducato[/HI]
Type of Body/ vehicle - [HI]Motor Caravan[/HI] ?
What is the CO2 for 2012 Hymer with Fiat 2.3 Multijet ? - for some reason not on the CoC [HI]Ring a Fiat commercial Dealer
[/HI]
best to take all the paperwork and forms to your nearest DVLA office and they will help answer the questions and register it there and then. not done one for a few years mind:thumb:
sedge
Jul 7, 2009
5,504
13,121
Nr Jct 3 M6
Aug 09 to date 9,000 miles!
Brum is the nearest, if they are still open. We are in Bedworth and I know we had to go to the one in Northampton the once some time in the last 14 years! but can't recall exactly what it was for now, or whether they told us that WAS the one for us as we are in Bedworth. Entering our (CV) postcode just though, it came up with Garrett's Green as the first choice.
T
twerly
38
71
Warwickshire
Hymer MLT 570
thanks, other than tax implications not sure if that is a good or bad thing ? Good for payload. Was not sure how it worked, i.e. the weight was the manufacturers weight - 3150kg.
Cheers
Steve
43,336
49,535
Cheers
Steve
no way on earth are you going to get a 4250kg gross weight van down to 3150kg and still have payload.
i would say 3150kg is the mass in running order, MIRO, the actual weight when it passed throught the factory gates when new and not the gross weight.
needs registering as 4250kg or you could come unstuck if stopped at a VOSA checkpoint.....and as a bonus, private heavy goods vehicle road tax is just ÂŁ165pa regardless of CO emmisions.
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
That's if they are still open as the Gov. are closing them all down in stages.
Check, before you drive to one, that it is still open.
pinkie
376
799
Angus
Hymer B555 Auto
newbie
Hi,
Just want to add, although the DVLA local office will look over form for you, to ensure it's correct, they can't actually do anything else. My local office (Dundee) was open for another month, but you are as well just sending it "Special Delivery" to Swansea, and wait for the letter back for any discrepancies. I didn't fill in the bits I didn't have the info. for and it went through (eventually).
Local offices even if still open are not processing anything, it is now all being done via Swansea.
Hi,
Just want to add, ...........................
How about this then !
From novice to Consultant in not much more than One FUN Month.
The power of FUN.
We could rule the world if we tried. But blow that, it would reduce drinking time.
T
twerly
38
71
Warwickshire
Hymer MLT 570
I know the 3150 is the MIRO, chose the better chassis to have it plated to give me good payload. I was just not sure if the DVLA 3500 was the MIRO or total maximum payload. In the event I have written a covering letter and left the Tax Class sections blank and sent the CoC and the original registration documents. I did complete the MIRO and the max permitted payload as per the CoC.
:Smile:
Steve
