It is, but they just look at it and check the pressure if they can get to the valve. They don't lower the wheel to grease the mechanismMany thanks , I’ll follow your advice. My garage told me today that an inspection of the spare was a part of the yearly vehicle service .
A 10 year old tyre is still ok for a spare ,its not been in the sun and I would think if you check it it's still got full pressure in. I just has a puncture and my spare was new in 2017 with the van, just dropped it ok from the hanger and lubricated the cable.Van 10yr old , never had cause to use spare wheel , it suddenly occurred to me that the tyre may be out of date or not fit for use . Any expert thoughts ? Cheers .
Bailey Approach 740 SE
I put an extension pipe on mine so I can check and inflate without lowering it.BUSBY.It is, but they just look at it and check the pressure if they can get to the valve. They don't lower the wheel to grease the mechanism
You can edit your response if you check the bottom left there is an edit button,its in the three little dots.Should read "well".
Brilliant!I put an extension pipe on mine so I can check and inflate without lowering it.BUSBY.
It has been unused for ten yearsIf it's not been unused for ten years and it's out of date why bother with it, take it down and leave it at home.
That's my understanding too, but either it's wrong, or the previous owner must have taken it out for the test! Mine was absolutely flat and very knackered, no way was it fit for service and I don't believe it could have been fit for use a year ago.Many thanks , I’ll follow your advice. My garage told me today that an inspection of the spare was a part of the yearly vehicle service .
