With this weather, for only 4 days you could keep the fridge stuff outside but depending upon where you're going be careful it doesn't freeze.We are going away this weekend fri to mon no hook up. PVC two 100ah batteries and 200w solar. My concern is with a compressor fridge and probably needing the heating on 24hrs plus the fact we will get negligible solar, will we run out of power ?
Without a doubt.............unfortunately.We are going away this weekend fri to mon no hook up. PVC two 100ah batteries and 200w solar. My concern is with a compressor fridge and probably needing the heating on 24hrs plus the fact we will get negligible solar, will we run out of power ?
Apologies for hijacking the thread.......You will propably just survive if you are careful, I don't understand why you would want the heating on 24 hours.
The Truma will take around 5-6 amps on startup but once the van is up to temperature will drop to about 1 amp (a bit more if you have the classic controls rather than the CP plus).
Idealy you don't want to run your batteries below 50% (unless they are Gels). 24 hours with the heating on you will be below 50% and that is without anything else running.
You say the van is well insulated so you shouldn't need heating at night and if it's sunny you shouldn't hardly need it during the day.
By not running the heating at night & during the day the fridge won't have to work so hard.
200 watts of solar won't do much at this time of year, if you have a good quality MPPT regulator on a bright sunny day with clear blue skies you may get around 10a/h on the south coast, less the further north you go.
The CP Plus does a far better job of control the fan and the boiler temperature. Being able to select the temperature you want in the van is far better than approx temp on the old dial and if you make use of the offset you can get it quite accurate.Apologies for hijacking the thread.......
Lenny - I have just bought the CP Plus control unit to replace the classic control of my Truma 4E and given that the CP unit only requires something like 30 to 60mA(from memory) I'm assuming that you're implying the Truma boiler is more efficient when controlled by the CP unit. Genuinely interested as to why - is it down to the CP having a microcontroller and thus better able to control the temp?
There should be a button to create a new thread for nerd questions like this - sorry to the OP again!!!
You could start with this thread:Thanks for all your ideas. Think will use the frozen bottle idea and the cooler box outside for beers. After all only away three nights. Interested in the BVM. Any chance of a bit more info.
