Strange Gas Fault (1 Viewer)
Patrick
366
11
Liverpool
2 year....Love it!
Ok, this has me and others really baffled!:Doh:
When we light the gas cooker rings or oven all is well, but if we then use our electric step or switch on the lights in the extractor fan over the cooker the gas goes of Why?????????
Any ideas ??????????????????????????
This never used to happen when we got the van, Jan used to be able to cook with the oven as we were driving
Douglas
2,835
400
South Wales,
Does your cooker have a glass lid? and if you close the lid does the gas go out? if so check that there is nothing behind the glass lid when open that is pushing the lid away from the wall, even the slightest amount can turn the gas off.
Doug...
23,836
72,550
How weird !
It MUST have some sort of safety device/cut off that activates if it detects a fall in battery voltage ( though lord only knows why !! )
As a first step get the multi meter on the leisure battery and make sure it is not dropping below 12v
Second, follow the main gas line and see if you can find a solenoid cut off.. As a temporary measure simply disconnect a wire going to it
Ahhh.. a thought and about the only reason I can think of for a cut off.....
I wonder if it has a widget fitted that will not allow the gas to be lit if the engine is running ? Again, can see that being a right pain in the parts but it IS a possible .. but that would take us back to option the second any way :Smile:
but if we then use our electric step or switch on the lights in the extractor fan over the cooker the gas goes off
You mean just the gas to the cooker ?
Don't know your cooker, is it all in one ? Does whole cooker go down ?
Some rambling thoughts.....
There must be an electric valve in there. Why ? Safety. What would trigger it ?
Power to this valve -- same circuit as step/fan -- fault in feed to step/fan/valve could be bad fuse contact - extra load valve drops out. Find fuse to step and see if pulling it kills cooker.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
when i read the header I thought it was going to be about baked beans:Smile:
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Is not having the gas on / cooking whilst on the move a touch dangerous?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
sounds like you have an LPG tank, and the valve (like mine) is and electric solenoid valve a high current draw such as a step could cause sufficient power reduction for the solenoid to drop out. are the batteries in good order, has the step been serviced lately. The solenoid can stick and needs occasional cleaning as well.
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
Doug...
Thanks Doug,
I will check that but doubt its the problem as it will happen to the oven even if the hob is not being used!
Patrick
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
The hob is Dometic Cramer, the oven is a separate unit and the heating does not go of when this happens to the cooking parts
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
Hi Wildman,
Yes we do have a gas tank, but the problem never seems to affect the Alda heating when this happens to the cooker……. Well I don’t think it does, or maybe just not noticed as the heating is so quiet and if it did cut of as its radiators wouldn’t notice.
Thanks mate I will check this out!:thumb:
Hycon
91
16
N.E Lincolnshire
just starting
|I belive that the gas should be turned off while on the road.I you are involved in a road traffic accident there is a possibilty of one big inferno and maybe aloud bang. Not to mention invalid insurance cover. :Eeek: Sid
