Spares help needed (4 Viewers)
Busman
1,766
4,332
Wirral
Esterel
A few years
i need a couple of reversing light sockets for my Buccaneer Cruiser 740 it says P21W on it, can anyone point me in the right direction please as not having any luck,
Thank You
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
I'm sure you could use these with a bit of thought & araldite.
dartslf2000
73
37
Wales
Since 1999
Not sure what the back end of a Buccaneer looks like of that age but you may find it easier to first identify the actual lamp unit, then find spare parts for it from that point. If they didn't utilise the PSA oe lamp unit then they more than likely utilised the generic Hella units etc of the time.
Dec 12, 2010
5,415
21,601
Cumbria
As above, check on the reflector or lens for Hella, Jokon etc then check out Leisureshop direct or O'Leary's (y)
Wickolad
490
542
Wickersley
These may be adaptable, 4x for just under £3 and free postage, plastic unit looks similar size so could well be made to fit. The P21W on your holder is just the bulb type, you may need to check the lense cover for the brand as mentioned above.
678
783
South Essex
15 in MH, 15 in Caravan
You may even end up like me... I have a broken front indicator on my Laika and haven't been able to find a replacement Hella unit so have gone for a similar but non branded LED unit from the USA...
Does mean having to change both front indicators though so they still match, but as they are LED they should last a while (I hope)...
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Thanks very much for the info appreciated. checked the lens and its a Jokon E4 9485
I've emailed leisureshop and waiting a reply, any others ????
Dave (y)
dartslf2000
73
37
Wales
Since 1999
And if the candle doesn't work:
Jokon G.B. Ltd.
Unit 24 · Dawkins Road, Poole GB – Dorset BH 154JD
Phone +44 (0) 1202 67 91 21 Fax +44 (0) 1202 66 57 73
info-uk@jokon.com
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Thanks again but not much luck they have even run out of candles :)
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
well I've had a couple of emails back saying would have to buy the lense as well so will go with Wickolads suggestion I think at least i'll have something and I can see if I can source the other if need be at a later date (y) Thanks all for your input even Phils cough
Badknee
7,408
413,046
notloB
Vantage Neo
Living the dream.
Every light fitting has a bulb holder to hold the exact same type of bulbs Dave be it side, brake, indicator, some with offset lugs so they are out there. Having to buy the whole thing including lens seems a bit extreme, even a car breakers should help?
Good luck (y)
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Thanks Paul I've ordered a set now and THEY WILL FIT,
Van off for its MOT in a hour been told you don't need reversing lights working.
Thanks again
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
With connections as in the second picture, I'm surprised they ever worked before. :rolleyes:
